Help with Engine Damper
Old Nov 19, 2006 | 10:38 AM
JCswoosher2's Avatar
OK. i have had my Engine damper for over a year. but i cant stand to have it on my car so it just sits in the garage. Every time i put it on. On a right turn its got HORRIBLE vibration. peopl in the car say WHAT WAS THAT. its embarrassing. and it helps a little. but id rather have wheel hop than the bad vibration. Am i doing something wrong? i can find a How To. Im just unbolting and putting the brackets on. But the shock doesnt fit all the way so i losen enough for it to fit n there. I dont jack up the tranny or anything. i would think the vibrations are messing up my motor mounts
Someone please help me because i would like to know what im doing wrong because im going to the track today. Thanks
Old Nov 19, 2006 | 10:42 AM
GSoccer24's Avatar
i don't have personal experience with it but i hope this helps (and that you haven't already seen it)
https://www.cobaltss.net/forums/how-guide-43/how-install-ingalls-engine-damper-your-cobalt-ss-sc-19559/
Old Nov 19, 2006 | 10:47 AM
even though i have a Weapon R Engine Damper. thats basically what im doing w/o WD40
Old Nov 19, 2006 | 11:50 AM
oh well. i just took the freaking thing off. who wants to buy it?
Old Nov 19, 2006 | 03:26 PM
godsfshrmn's Avatar
Maybe you have it too tight? When you get in low RPM like on a turn, it will start to shake. Its not as bad if the damper is on stock setting
Old Nov 19, 2006 | 04:06 PM
2K5SS/SC?'s Avatar
The Weapon R one sucks. The Ingalls unit is a nice piece. I have a little bit of vibes every now and then, but nothing bad. It really helped out with the wheel hop as my second trip to the drags didn't end on the first try with a snapped axle @ the 60' mark. I actually drove my car home on by it's own means after 10+ passes!
Old Nov 19, 2006 | 04:14 PM
06blackg85ss's Avatar
dunno make sure you have it set right... I"ve installed a few of them on peoples cars without that horrid vibration.. yes your gonna get some due to what it does but not as bad as you decribe.. I personally have the ingalls on mine... no problems here.
Old Nov 19, 2006 | 04:18 PM
NightriderCobaltSS's Avatar
Alot of people have said like Dynamat Extreme on the firewall will keep the vibs out
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DANRICKARD
Oct 1, 2015 12:08 AM
cw383
Sep 30, 2015 12:41 AM
