Help!!! Fast!!!
Old Aug 19, 2010 | 11:01 PM
  #51
Brenticus's Avatar
In other words: is it something only a dealer can do? Is it expensive? Is it a type of tuning I guess?
Old Aug 19, 2010 | 11:08 PM
  #52
RAY321's Avatar
The vehicle should be drivable without the relearn, the pcm would have very conservative settings like spark timing until it has the relearn to bring it to life. But your car sounds like something is amiss?
Old Aug 19, 2010 | 11:11 PM
  #53
RAY321's Avatar
It could be as much as $80, but I have heard of dealers doing it for free.
Old Aug 19, 2010 | 11:15 PM
  #54
RAY321's Avatar
HP tuners software is capable of doing the relearn if you or someone near you has access to it that will get you out of the dealership. But the car has to idle in fact I believe that they have to raise the idle to 4k. Does your Cobalt idle? and can you raise the idle to 4k?
Old Aug 19, 2010 | 11:30 PM
  #55
cli3e0339384398jk's Avatar
i would find it very hard to believe a case relearn issue would be causing this.....
Old Aug 19, 2010 | 11:32 PM
  #56
try putting your old injectors back in and see if it runs, also try putting your old pcm back in. Just try one thing at a time until u isolate the problem
Old Aug 19, 2010 | 11:41 PM
  #57
RAY321's Avatar
Thumbs up
Good idea I agree.
Old Aug 19, 2010 | 11:59 PM
  #58
Brenticus's Avatar
I just bought an obd scanner. Would that maybe work?
Old Aug 20, 2010 | 12:02 AM
  #59
06SuperSportChevy's Avatar
I'm telling you guys it's not the case relearn making the car not driveable. Mine ran awesome for the day When I installed my new PCM. It just threw a code for "crankcase variation not learned".
It's definatly something else in the kit that went wrong.
Old Aug 20, 2010 | 12:07 AM
  #60
RAY321's Avatar
OBD scanner is good to have for retreaving codes but it's not going to be able to do the crank relearn.
Old Aug 20, 2010 | 12:38 AM
  #61
Originally Posted by Brenticus
The codes I have are P0315 and P0118. From what I understand the P0315 code is most likely case relearn. Can someone please explain to me what that is? The other is something to do with the coolant sensor. Any thoughts?
P0315 won't affect the driveability of your car. Its definatly the P0118 code that is messing with it. Maybe it's the sensor itself.
Old Aug 20, 2010 | 12:40 AM
  #62
^Just a thought... Hopefully someone with more exerience will chime in.
Old Aug 20, 2010 | 02:03 AM
  #63
Brenticus's Avatar
Well after I cleared the codes the car dropped the limp mode and will now let me drive it. I'm just afraid to. The idle is still a tad choppy but nothing like it was. Before the whole motor was jarring around. Now the idle just studders a bit. The car also won't read the coolant temps. Other than that it's good.
Old Aug 20, 2010 | 07:48 AM
  #64
kyle1853's Avatar
Lol.. I told you that would prolly work ...but thats not good that it wont read coolant temps
Old Aug 20, 2010 | 10:28 AM
  #65
Brenticus's Avatar
Agreed. I'm close to getting this resolved. Just needs a little more and I'll be back to driving my baby again.
Old Aug 21, 2010 | 03:40 PM
  #66
corey_osu10's Avatar
sir you need a case relearn. im having the exact same issues as you and throwing code 315 as well and i just installed ottp stg2. and 06supersportchevy, just bc your car didnt do it doesnt mean his isnt. some cars need a relearn and some dont as no to crank sensors are alike however some match enough while most dont. take the car to a dealer to get a relearn but dont delete your tune and this should fix your problem. hope this helps
Old Aug 21, 2010 | 03:43 PM
  #67
gwatson650's Avatar
mine did the same. i had the lines backwards that go to the intake, and the actual s/c
Old Aug 21, 2010 | 04:09 PM
  #68
AnthonyCM's Avatar
its the case relearn just find someone with HPT near you an they don't even need to unlock your car to do it...or if you have an interceptor i believe you can do a case relearn with it too
Old Aug 21, 2010 | 06:01 PM
  #69
mine did need it... I just stated that my car ran fine while it was throwing that code. And ran the exact same after it went through a relearn. It literally ran awesome before and after.
Old Aug 21, 2010 | 06:03 PM
  #70
an interceptor will not perform this. you either need hptuners or tech2.
Old Aug 21, 2010 | 07:17 PM
  #71
AnthonyCM's Avatar
i said i believe meaning i wasnt sure
Old Aug 21, 2010 | 07:29 PM
  #72
Cherry GT's Avatar
Originally Posted by 06SuperSportChevy
It's definalty not the case relearn. My car ran awesome before it went through a relearn, just threw a code for "crankcase variation not learned".
Agree... Its not the case learn thats the problem
A dash hawk can do this also.
Still agree with this man !
Its not a case learn problem !
Old Aug 21, 2010 | 07:39 PM
  #73
Thank you!
Old Aug 22, 2010 | 12:06 AM
  #74
07Slobalt_1's Avatar
i have the same kit as you. i had throttle body issues after i installed the kit. so, try this, unplug the battery, then unplug the throttle body, then unplug the sensor down at the gas pedal in the car itself. let it sit for about 15mins or so. then plug both sensors back in and hook your battery back up. see if that helps! fixed my problems. now i just need a tune bc the zzp one sucks. so get used to the erratic idle!
Old Aug 22, 2010 | 01:55 AM
  #75
try this and if it doesnt work, GO GET A RELEARN. lol
