HELP gas tank.
Old Jul 20, 2010 | 02:17 PM
superslowbaltss's Avatar
HELP gas tank.
dose anyone have a link or picture showing exactly where the gas tank is on my 2006 chevy cobalt ss?
and any gas lines or anything that contains gas that is near my trunk space.
thankyou,
superslowbaltss.
Old Jul 20, 2010 | 02:18 PM
K-Train04RL's Avatar
ur gas tank is like underneth the car infront of the trunk.
Old Jul 20, 2010 | 02:21 PM
so pretty much under back seat?
the reason i ask for pictures is that i am trying to mount bars in my trunk and need to know when i drill and thread holes that i am not drilling into anything extreamly important.
need more help please. (Pictures)
thankyou,
superslowbaltss.
Old Jul 21, 2010 | 03:06 AM
Dainslaif's Avatar
You're probably better off just putting the back of your car in the air and drilling the holes with it up, so you can check yourself. Just drill from the bottom.
Old Jul 21, 2010 | 11:54 AM
the problem with that logic is that the car is not made from one layer of metal.
and im not trying to drill into the bottom.
i am trying to drill in the sides, such as near ''where the fuel is filled''
thankyou,
superslowbaltss.
Old Jul 21, 2010 | 11:56 AM
Godly's Avatar
thankyou,
superslowbaltss.
The gas tank is located basically right behind the back seats.
Sorry for no pictures :S
Old Jul 21, 2010 | 01:48 PM
Dainslaif's Avatar
thankyou,
superslowbaltss.
Then take off the rear side panels and drill in through there. You'll need to take them off anyways unless you're planning on drilling through the body itself.
Old Jul 21, 2010 | 03:10 PM
didnt even know the rear outside panels were panels and that they come off.
thankyou,
superslowbaltss.
Old Jul 21, 2010 | 03:32 PM
cmatthewb101's Avatar
The tank should clear the trunk. I had to swap out my fuel tank, you should be fine aslong as you don't drill through towards the seats
I just took some pics, best as i could. gimme a min
In this pic, you can see the fuel hose that carries the fuel from the door, into the tank. (right next to the tube with the blue clips) It should wrap around the trunk itself, so you shouldn't have an issue with that.
The tannish/silver tank closet to the camera is the trunk. Infront of that is a black box with fuel lines going to it, then the bar going across the car, then on the other side of that is the fuel tank. So see, a good 5-6 inches separate them.
Last edited by cmatthewb101; Jul 21, 2010 at 03:34 PM. Reason: Automerged Doublepost
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
