Help im squeaking!!!
Old Jul 18, 2008 | 08:09 PM
Spectral's Avatar
So my car is squeaking like a *****.
We worked on my car yesterday and it seems when we put the belt back on we failed to put the bottom part of the belt on all the way correct and its not on fully so it squeaks a lot.
We used a 14mm wrench shaved a lil bigger to get the tensioner pushed back. But i cant make it to his place and the shaving is taking forevvver on this.
is there an easier tool that i could use other than the actual tensioner tool??
Old Jul 18, 2008 | 08:14 PM
outtamymind's Avatar
word of advise. when it comes to things like belts or anything else important its a good idea to use the correct tool. and have you tried using a ratchet on it. i've only ever had to use wrenches to release the tension on the tensioners
Old Jul 18, 2008 | 08:16 PM
Spectral's Avatar
thats what i have to do i have to release the tension so i can move the belt.
Old Jul 18, 2008 | 08:28 PM
well all you have to do is release the tension enough to move it. now remember you want to have as long of a handle as possible as it makes it much easier to move the tensioner. it's sometimes easier with 2 people on some cars but with ours, there isn't a whole lot of room.
Old Jul 18, 2008 | 08:30 PM
Spectral's Avatar
did you use a 15??
Old Jul 18, 2008 | 08:34 PM
rnjmur's Avatar
I know pulleyboys has a belt tension release tool that works really well. Using a wrench sucks and is almost impossible.
Old Jul 18, 2008 | 08:37 PM
Spectral's Avatar
the 14mm shaved works fine but i cant get his so im sitting here having to shave a 14mm i have and its taking foreverrrrrr.
Old Jul 18, 2008 | 08:48 PM
Originally Posted by Spectral
did you use a 15??
can't remember which one i used. if you like i can look up what tool it should be from gm's service website. sorry it doesn't say it just tells us to get a J tool. but a 15mm should work.
Old Jul 18, 2008 | 09:25 PM
chief_nukka's Avatar
go to the pawn shop and find what you need and if that doesnt work go to autozone and ask for the tool you need and they usually loan out special tools like that. if that doesnt work go to your gm dealer and sweet talk the lady at the desk for the "coolest" mechanic they have and see if he can help you. dont talk money to anyone just ask if you can go back and talk to the mech and more than likely he should help you and if he doesnt find someone that will. dont ever pay for something that can be fixed by you.
Old Jul 18, 2008 | 09:31 PM
qwikredline's Avatar
the belt is misaligned on one of the lower pulleys. noneed to shave a wrench get and open end one that fits (15mm i think) steady pressure back to the rear of the a car on the tensioner relieves the tension; then put the belt back on correctly so it runs in all the grooves on all pullies....good luck
Old Jul 18, 2008 | 09:34 PM
theneelster's Avatar
That's pretty bad dude...did you shred the belt? Take the stage 2 pulley off with the belt on (slide it off) and reguide the belt then do the reverse with someone working the tensioner to get it back on (make sure the bolt holes are lined up).
Yeah the pulley boys tensioner tool pays dividends...unless you over extend it and your tensioner sticks (which means you're fuc*ed and have to tow it to the dealership to get fixed) Yeah...I'm THAT guy.
Old Jul 18, 2008 | 09:57 PM
04Redline's Avatar
I just use a 15mm wrench.... the trick is to be at least .... 180 lbs and put your weight ontop of it and then push!
Old Jul 18, 2008 | 10:11 PM
Spectral's Avatar
i got the 14 to work and the belt is fine.
Old Jul 18, 2008 | 10:41 PM
good for you add that to your list of life experiences and you wont make the same mistake again, and when someone next week chimes in with thesame problem u can help them out....
Old Jul 18, 2008 | 11:33 PM
Mr_Slobalt's Avatar
I got frustrated with the 15mm open end and used a pry bar lmao
Infamous SC/SS
Sep 4, 2015 05:33 PM
07cobaltss
Sep 19, 2007 12:38 PM
L.P.
Jul 9, 2007 01:02 AM
YellowG5
Jul 5, 2007 02:25 PM
nickabud
Feb 9, 2007 05:38 AM
