help installing pulley!!
Old Sep 11, 2007 | 05:49 PM
Altiery54's Avatar
i am putting a 3.15" on 2nite after work. i know there is a few threads on this already of how to take the s/c off and put the new pulley on could someone post a link or give a brief explenation of how to do it
chris
bum,p
Old Sep 11, 2007 | 05:53 PM
1BADSS/SC's Avatar
chris
I dont have pics, but I can give u an explaination of how to do it:
step
1) Make sure U have someone to help u
2) have that person hold down the pulley
3) remove bolts with whatever tool is needed
4) this is the tricky part. Get a 15mm cresent wrench, and look for the belt tensioner. It is located after the sc pulley, but before the engine. It will kind of look like a square, and the wrench will fit perfectly on it. Its black in color, and will be located in the vicinity of the other pulleys attached to the belt.
5) PUSH DOWN VERY HARD, THEN SLOWLY PUSH FORWARD. You dont want to strip it, and it will be difficult to move.
6) once u have it pushed all the way forward and are holding it down, have your friend remove the belt.
7) let off the tensioner once the belt is off, but MAKE SURE NOT TO DROP THE BELT.
8) remove the pulley, put your new pulley on
9) loosen the tensioner
10) slip the belt back on
11) let go of the tensioner, and bolt your new pulley in place
hope this helps
Old Sep 11, 2007 | 05:55 PM
Altiery54's Avatar
thanks bro much appreciated
red06s/c's Avatar
I took mine to advance auto parts, they put it on for me and it was free!
Old Sep 11, 2007 | 05:57 PM
1BADSS/SC's Avatar
I wouldnt trust those a#$ clowns. Most of em are unexperienced kids, and they wouldnt know their a#!hole from a hole in the ground. I had a couple recommend parts, and the damn things wouldnt even work in my car...
Old Sep 11, 2007 | 05:58 PM
Altiery54's Avatar
hahah me and my old man are gonna do it
Old Sep 11, 2007 | 05:59 PM
1BADSS/SC's Avatar
its pretty easy, takes about 10 min. I would recommend tying the wrench to something so u dont lose it. I hate dropping stuff in the engine bay.... I tied my wrench to the car so that I could just pull it out if it fell
Old Sep 11, 2007 | 06:00 PM
red06s/c's Avatar
i was just saying....i went to rent the tool and they did for me and i havent had any issues with it.
Old Sep 11, 2007 | 06:05 PM
Altiery54's Avatar
i am taking it you dont take the s/c off then..
i was planning on having to take the supercharger off if u dont it will make my life easier
Old Sep 11, 2007 | 06:09 PM
1BADSS/SC's Avatar
nope, no sc removal. So long as u can remove the bolts and the pulley fits on ok, you dont need to remove it.
Old Sep 11, 2007 | 06:11 PM
Altiery54's Avatar
ya i got one of nates pullies so it should fit fine but it seriously only took 10 MINUTES??
Old Sep 11, 2007 | 06:14 PM
1BADSS/SC's Avatar
yup, so long as u have 2 peeps.
Old Sep 11, 2007 | 06:15 PM
Altiery54's Avatar
awesome man! i get off work at 8 and me and the old man are putting it on i will post on how it pulls once its on
Old Sep 11, 2007 | 06:18 PM
Killa SS's Avatar
umm do u have like a gm hub on there or is it a press on pullie?
Old Sep 11, 2007 | 06:43 PM
Altiery54's Avatar
its whatever is stock on the car
Old Sep 11, 2007 | 07:33 PM
nherbst454's Avatar
He bought a complete kit so it's going to be a bit more involved since it requires the stainless steel hub be pressed onto the supercharger shaft.
You'll have to remove the supercharger then use a pulley puller/isntall tool to remove the pulley from the supercharger.
Then use the threaded rod part of the puller which has a m8 x 1.25 threaded piece in the end to attach it to the supercharger shaft.
Next, place the pulley over the threaded rod, then the washers, and finally the nut. Start cranking the nut while holding the threaded rod steady.
It will help to have someone hold the pulley while you press the hub on otherwise the shaft may begin spinning and un-threading the M8x1.25 threaded piece which can result in a stripped threaded rod.
When the hub face is flush with the end of the supercharger shaft you're done and ready to re-install the supercharger.
Hope this helps,
Nate
Old Sep 11, 2007 | 07:38 PM
Killa SS's Avatar
yea thats pretty much it. i just did mine yesterday by myself and it wasnt that hard. took me a lil over an hour
Old Sep 11, 2007 | 07:41 PM
Altiery54's Avatar
damn this is the best now i know exactly what i am doing thanks
+ rep everyone
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
