Help intense stage 3
Old Mar 20, 2008 | 07:47 PM
SSCobalt~SSZ24's Avatar
ok so my question is how far does the new hub need to be pressed onto the blower shaft? i pressed it on so the end of the shaft was flush with the pulley end of the hub......buut wheh i sit the blower down it looks like the pulley is out a little far and the belt wont ride right
sorry for the grammar on my wii
any suggestions
Last edited by SSCobalt~SSZ24; Mar 20, 2008 at 07:47 PM. Reason: Automerged Doublepost
Old Mar 20, 2008 | 07:48 PM
Psykostevo's Avatar
any suggestions
Mount the hub flush. The pulley is bigger than the belt. It is an 8 rib pulley and the belt is 6 rib. It WILL stick out farther, but just mount the pulley all the way to the right so that it stays in line with the other accesories.
Old Mar 20, 2008 | 07:52 PM
Joeyavhu's Avatar
It should be so that when you stick on the new pulley to the hub, the belt will be straight with one extra rib on each side. If you need to have the belt slightly angled or not on the correct ribs, you should just push it in a little further. If you need pictures, let me know.
Old Mar 20, 2008 | 07:54 PM
i know its wider but the belt looks like its gonna ride about a 1/8th of an inch inside of the last rib on the pulley
the hub could go on further but ite flush aith the end of the blower shaft
need pics for sure man thanks a lot
Last edited by SSCobalt~SSZ24; Mar 20, 2008 at 07:54 PM. Reason: Automerged Doublepost
Old Mar 20, 2008 | 08:19 PM
Joeyavhu's Avatar
Here, let me know if this helps, to give you an idea of how it should look.
Old Mar 21, 2008 | 11:50 AM
Psykostevo's Avatar
Are you sure? All the ones I have seen line up with the pulley all the way to the right, not in the middle. And I have done about 40-50 of them.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
