HELP MAP/MAF code.
Old Apr 26, 2008 | 02:56 PM
Kennyspec's Avatar
HELP MAP/MAF code.
Hey just took out the turbo balt, after i go over 3000rpm i get the p0068 MAP/MAF correlation code......whats this from?? I cant even get into the throttle without going into reduced power mode. Help me out, im going go go work on the car a bit more hopefully someone will have the answer for me when i get back.
Old Apr 26, 2008 | 03:11 PM
Hopeless Regret's Avatar
Sounds like a bad MAF sensor, I had same problem with mine, Tried cleaning but didnt do anything. I would start there.
Old Apr 26, 2008 | 03:17 PM
Bika's Avatar
Fail Less.
go into the diagnostics in hptuners and set the enable rpm for p0068 to 8000 rpms. problem solved
Old Apr 26, 2008 | 03:30 PM
That sounds good Bika, Gotta Love HP
Old Apr 26, 2008 | 03:35 PM
Bika's Avatar
Fail Less.
yup hpt FTW
for the 2007 ss/sc GM actually set p0068 to 8000 rpm. they hadn't yet figured that one out in '05 and '06
Old May 17, 2008 | 09:21 AM
Maxim_X's Avatar
I have this same code with my turbo. How safe is it to do that?
Old May 17, 2008 | 09:22 AM
originaladrian's Avatar
u have no choice
Old May 17, 2008 | 10:51 AM
Area47's Avatar
Rent me! per hour
you can either. live with it in limp mode. or shut it off.
turbo vs blower.
my advice, shut it off.
Old May 17, 2008 | 10:52 AM
BlackSS/SC's Avatar
Shut it off, no way around it. Mine's been shut off since I went turbo.
Old May 20, 2008 | 06:22 PM
Hodz's Avatar
Im having this problem too with my supercharged cobalt... I keep taking it to the nearest GM dealer and they said they cant figure out whats wrong with... They replaced my MAP sensor but my check engine light still keeps coming on...
Old May 20, 2008 | 06:26 PM
Area47's Avatar
Rent me! per hour
replace the mas air sensor.
Old May 22, 2008 | 10:17 PM
Hodz's Avatar
ok my MAF and MAP sensors have both been replaced but i still have a MAF/MAP correlation code on. Any ideas why?
Old May 24, 2008 | 01:45 AM
Bika's Avatar
Fail Less.
what exactly is the DTC number, and what mods does the car have?
Old May 25, 2008 | 02:16 PM
Hodz's Avatar
I had my car in the shop for almost about a month and GM couldnt figure out my problem.. They replaced both my MAP/MAF sensors and I still had my code coming on. I just happen to put on a cold air system and it fixed everything. My stock air box had a huge hole in it which i think was causing that code to come on.
Sean Cummings
Mar 9, 2018 12:26 AM
Dustin24
47
Feb 12, 2016 04:10 PM
OrangeCoba
Sep 25, 2015 06:06 PM
