Help Me!!!
Old Sep 6, 2007 | 01:43 PM
smileyturbo's Avatar
Help Me!!!
Where Can I Buy A Stage 2 Belt For My Custom Made Stage 2?
So Far I Got
Stage 2 Injectors
2.9 Pulley And Hub
So This Plus A Vist To The DeaLer To Flash My Stock Ecu Should Be Enough Righttttttt?
Old Sep 6, 2007 | 01:45 PM
Area47's Avatar
Rent me! per hour
dealer can get them. or one of the magical sponsors can off this board.
Old Sep 6, 2007 | 01:46 PM
JMAc88's Avatar
Check crate engine depot to order a belt.
No, you can't just walk into a dealership and ask for a stage 2 flash. You either have to buy stage 2 at this point (pointless) or go get it customed tuned somewhere in your area.
Old Sep 6, 2007 | 02:13 PM
BadSS2006's Avatar
Actually, I called my chevy dealer awhile back and told him I had a pulley and injectors already and just needed the ECU reflash. He said it costs $84 and takes about an hour. Its just not covered under any kind of warranty like if you bought a whole stage 2 from chevy. Some dealers may be different, but if you call around, it shouldn't be a problem. I decided to wait because its $84 for the stage 2 reflash, or $124(+core charge) for a whole new ECU from ZZPerformance.com that will yield more power and give you more options that you can't get with the stage 2. Its only $40 more, which I think is worth it.
As far as the belt, I bought mine from www.cobalt-addiction.com. It was $49 via paypal shipped, I got it about 3 working days later. A brand new belt. Its kinda nice buying there because you can use paypal, no credit card required.
Old Sep 6, 2007 | 02:17 PM
heyitsmikey1987's Avatar
chevy dealer or zzperformance .com
Old Sep 6, 2007 | 06:04 PM
nherbst454's Avatar
So Far I Got
Stage 2 Injectors
2.9 Pulley And Hub
Hmmm...So Why A Capital Letter At The Beginning Of Each Word?
Old Sep 6, 2007 | 06:15 PM
Area47's Avatar
Rent me! per hour
because he is trying to type in caps in the quick reply box
victory_red_SS's Avatar
LSX RWD S/C conversion
I have one but it is likely easier to get one locally.
Old Sep 6, 2007 | 06:16 PM
an0malous's Avatar
how is the dealer going to flash your ecu when you dont have the stage 2 flash calibration code?
Old Sep 6, 2007 | 09:21 PM
so how can i tune my car if i dont have the codes using hptuners???
Old Sep 6, 2007 | 09:24 PM
an0malous's Avatar
you can tune your car with HPtuners certainly.
but you said "off to the dealership to flash my ecu"
the only way the dealer can flash you with a stage 2 tune, is if you have the stage 2 tune calibration code that comes with the S2 kit.
Old Sep 6, 2007 | 09:53 PM
anthonyS88's Avatar
i think cobalt addiction also has them
Old Sep 7, 2007 | 12:19 AM
JMAc88's Avatar
When you buy stage 2 you get a code that allows them to download the program to flash onto your car. Once the code is used, it is vin locked to your vehical.
Unless the dealer somehow saved a tune from someone elses flash and are offering it to you, but i don't know if that is possible and if it is, its really shady.
The zzp ecw us almost plug and play. It already comes tuned so you swap out your stock ecw, and then have to take it to a chevy dealership for a case relearn. Don't think that costs anything?
I would still recommend a custom tune with hp tuners in your area, just because:
a) every car is different...supporting mods ect....
b) a bought tuned is frequently done in a different enviroment then what you are in, which my cause some problems with the tune.
Old Sep 7, 2007 | 01:11 AM
2.0freakotec's Avatar
ok what smiley turbo is talking about is the reflash that has 7 upgrades for our car it doesnt make it any faster it just makes the car a hell of a lot smoother i got it done about a month ago it cost $125 it will fix the P0171 and will also fix the miss fire code its a really good idea to get it done but it wont make it faster just smoother hope this helps
P.S. smiley turbo its not a stage 2 reflash so dont get ur hopes up go with a tune
Old Sep 7, 2007 | 12:32 PM
thxs guys , im gonna try talking to some dude named Ljavy17 he is somewhere in fl im gonna see if he can tune me supposively he is good at it...
