Help Me Out Here
Help Me Out Here
i no i will most likly get flamed for this but w.e i need to no it....puttin 60# on wit a pulley size 2.8 or higher is bad.... or not
so basicly im askin is it bad to put 60# on a 2.8 or higher pulley or is it fine because i absoltly do not want to take any chances and lik to be 110% on the safe side
Injectors which are too large for an application are harder to tune for driveability purposes, which isn't a problem as someone has probably already developed a tune which will work. You should look into 50s.
but as my sig says i do have 50lbs and 2.8. i talked to cobalt addiction cus theyre doing my tune and they said they should work good. my guess is that they wont be over used like 42s and they wont be underused like 60's
ya inoticed that ur the only 1 wit the 50s i was going to ask u about them....but the thing is i dont live in the states
and not many pplz around me can tune or n e thing im not even sure
thats ok. just install the parts and send out your pcm to a tuner. itll cost you a good week or so of no driving.
