Help Me Out Here
Old May 7, 2007 | 05:13 PM
killah_thug08's Avatar
Help Me Out Here
i no i will most likly get flamed for this but w.e i need to no it....puttin 60# on wit a pulley size 2.8 or higher is bad.... or not
so basicly im askin is it bad to put 60# on a 2.8 or higher pulley or is it fine because i absoltly do not want to take any chances and lik to be 110% on the safe side
Old May 7, 2007 | 05:15 PM
AROON02's Avatar
Im Not Sure But I Think 2.7 Or Smaller Is 60#'ers
Im Sure Youll Get A Detailed Response To This One
Sales@rebelautoworxs's Avatar
60lb injectors and 2.8 pulleys are a great combo
Just need a tune file to do it. Most of the vendors can help you out with a tune file.
Old May 7, 2007 | 05:26 PM
another flamin question.... lol wat a tune file....is it like a certian tune made ofr the 60#ers and 2.8 pully...i will get back to this post but i gotta go out now
Old May 7, 2007 | 05:34 PM
Mattman6's Avatar
it is tune that is used in HP tuners, you must have Hptuners to use the tune however
Old May 7, 2007 | 06:10 PM
Area47's Avatar
Rent me! per hour
60lb injectors are over kill on a 2.8
Old May 7, 2007 | 06:53 PM
over kill meaning it will **** things up or wat
Old May 7, 2007 | 09:00 PM
LopsidedJester's Avatar
no, if you have the right tune for 60 pound injectors which is somewhat above what is needed, you won't **** things up, you just won't be using the full potential of the injectors.
Old May 7, 2007 | 09:48 PM
Mikey851's Avatar
Injectors which are too large for an application are harder to tune for driveability purposes, which isn't a problem as someone has probably already developed a tune which will work. You should look into 50s.
Old May 7, 2007 | 11:48 PM
Boost Fr33k's Avatar
id like to add to this because it seems as if im the only one arond here with 50lb injectors. BUT theyre not installed yet
but as my sig says i do have 50lbs and 2.8. i talked to cobalt addiction cus theyre doing my tune and they said they should work good. my guess is that they wont be over used like 42s and they wont be underused like 60's
Old May 8, 2007 | 12:01 AM
ya inoticed that ur the only 1 wit the 50s i was going to ask u about them....but the thing is i dont live in the states and not many pplz around me can tune or n e thing im not even sure
Old May 8, 2007 | 01:32 AM
thats ok. just install the parts and send out your pcm to a tuner. itll cost you a good week or so of no driving.
