Help: Megan Exhaust Install.
Old Apr 9, 2008 | 04:37 PM
Nichq's Avatar
Going to be installing my Megan Racing exhaust tomorrow. I wanted to make sure that I have all the parts cause the exhaust came with no instructions. I have the 3 pieces that connect for the exhaust. Not sure if it should have come with gaskets to go in between the connections, or if i use the stock ones, or if it even uses gaskets.
Old Apr 9, 2008 | 04:39 PM
rguti153's Avatar
how much you bought it for ? im looking for one
Old Apr 9, 2008 | 04:40 PM
umrdyldo's Avatar
my nuts, bolts and gaskets were already bolted to the ehaust. The gaskets are the thin little pieces of metal attached at each end of the pieces.
Look again.
Old Apr 9, 2008 | 07:11 PM
Nichq's Avatar
Look again.
Thanks man. Thats kind of what I figured those were. Had to make sure though.
Old Apr 9, 2008 | 07:58 PM
Cobalt(312)'s Avatar
Yeah i had to cut my exhaust before the trailing arm in the rear to put mine in and bend my heat sheild back a little so the flange coming off the resonator didn't vibrate in it.
Old Apr 9, 2008 | 08:54 PM
Nichq's Avatar
Got one of the last ones from NGA in the latest GB for 330 shipped. Dont think they are getting anymore in for awhile unfortunatly.
Old Apr 9, 2008 | 09:59 PM
umrdyldo's Avatar
I also ran into the heatshield problem right behind the resonator. I think it was my fault though.
I also have a leak there that I need to fix.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
