Help with meth system.
Old Feb 23, 2008 | 01:01 AM
invisible's Avatar
It says to slice the the wire into the 5volt outputsignal of you map sensor. Can anyone tell me witch wire this is?
Old Feb 23, 2008 | 01:09 AM
Sunburst_SS's Avatar
5 volt ref. is the dark green wire, pin 3
MAP sensor signal is the Grey wire, pin 4
pretty sure you need the grey wire for the signal you need
Last edited by Sunburst_SS; Feb 23, 2008 at 01:09 AM. Reason: Automerged Doublepost
Old Feb 23, 2008 | 01:12 AM
invisible's Avatar
Thank you so much. Is that what you tapped into when you did yours?
Alright ill try it first then, Is there anywhere else that i can tap into it besides right by the map sensor?
I don't have ameth kit on my car.......however, if it's that MAP signal you need....that's the wire you need
you could tap into the wire anywhere you like really, doesn't have to be right on the sensor
Old Feb 23, 2008 | 08:41 PM
invisible's Avatar
Well I made a 150.00 dollar mistake and fried my progressive controller.
Old Feb 23, 2008 | 09:37 PM
what did you do?
Old Feb 24, 2008 | 01:55 AM
invisible's Avatar
Haha I didnt ground the controller.
What are you guys using for power on your meth kits?
Old Feb 24, 2008 | 01:57 AM
95cam86roc's Avatar
subscribed
Old Feb 24, 2008 | 02:03 AM
invisible's Avatar
Haha Yea it fryed it right away, I heard a pop, smelt some smoke and well you know, I didnt think not grounding it would do this, But you live and learne i guess.
Old Feb 24, 2008 | 03:47 PM
2K5SS/SC?'s Avatar
Boost sensor FTW! Screw all that progressive stuff, it's a waste of money IMO.
Old Feb 24, 2008 | 04:06 PM
KillerNutz's Avatar
QFT!
Old Feb 24, 2008 | 09:55 PM
invisible's Avatar
Haha Would it be compatable with the devils own??
Where are you guys hooking the power wire up??
Old Feb 24, 2010 | 05:15 AM
06SIBLT's Avatar
sweet.
Old Feb 24, 2010 | 05:18 AM
Zach06CobaltSC's Avatar
Holy resurrection Kyle. Go to bed we have tuning to do tomorrow =D.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
