Help with meth system.
5 volt ref. is the dark green wire, pin 3
MAP sensor signal is the Grey wire, pin 4
pretty sure you need the grey wire for the signal you need
Last edited by Sunburst_SS; Feb 23, 2008 at 01:09 AM. Reason: Automerged Doublepost
Thank you so much. Is that what you tapped into when you did yours?
Alright ill try it first then, Is there anywhere else that i can tap into it besides right by the map sensor?
I don't have ameth kit on my car.......however, if it's that MAP signal you need....that's the wire you need
you could tap into the wire anywhere you like really, doesn't have to be right on the sensor
Haha Would it be compatable with the devils own??
Where are you guys hooking the power wire up??
