Help! My ecu is locked
ok so i took my car to a local shop with hptuners yesterday to get tuned and they couldn't access my computer because whoever installed my gm stage 2 at the dealership locked up my computer to where i can't put a tune on the ecu. has anyone else experienced this problem from the gms2 tune?
as far as I've seen in the 4 years I've been tuning these thing you can't tuner lock the ecm. and the issue people probably have with ZZP is they don't have the newest beta version of the software so you can't read the file.
thanks for the help. the shop i went to has tuned many lsj's and lnf's so i'm a little confused as to what is going on. the guy that helped me sent an e-mail to hptuners with the file attached so hopefully he will hear back from them and it will get worked out. i'm just a little nervous because i have to pass emissions by the end of january and i need to get a code deleted
Can you post up an HPT infolog for us?
http://www.hptuners.com/help/demos/infolog.swf
also, what error was coming up? Invalid OSID/VIN pair or something else? Please be as specific as possible.
you can lock lsj pcms, ASK OTTP lol they do themselves. a member on here had a canned tune from them and i was gonna fix his pos tune but could because it was locked. thank god he had a spare pcm..
member name is cobaltss89
Yeah I highy doubt that since I tuned 10 balts that day and he had his spre pcm. So I tuned it. I tried more then 5 times and his pcm was locked. It would start loading the tune then stop saying we couldn't download it because thr pcm was locked. I'm not lieing m kyle cobaltss89 and ask for ureself.
Nope
..... are u doing it correct. Did u use a old beta ecu tune with a new beta. I know the ecu I tuned was locked because e had a spare cm, and I tuned several balts that day. I tried multiple times to download the tune but nope coudnt. It said sonthing about it being locked or somthinf to that sort.
Nope
Make sure you are using the right vin #. I had so much trouble getting trifecta tuned one time first because I did not have the right cable for an 06 and second because I had a zzp canned tune that was a different vin # and was also off of a damn malibu
