Help No Dyno Need HPnumbers
i was wandering if anyone could help me with HP numbers, Theres no dyno in alaska and was wondering what i might be pushing with my mods
gm stg 2 reflash, 42lb injectors, 2.79 pulley,injen cai, hahn header, D/P, and exhaust, dual pass intercooler, cobra H/E. And it runs about 17-19 psi
MY Guess would be about 240whp and 220ft/lb
Any one running the same setup i know someone is
2.79 is pretty small to be running the GM tune and injectors. I say about what you think for horsepower is relatively close. you may want to consider 60lb injectors and a custom tune before you go lean and bad things happen.
im saving for the injectors but like i said no dyno and no one to tune it here. no check engine light yet.
i know a dude that just started using hp tuner but hes not sure about it yet
you won't get a light as far as i know. someone should be able to send you a pretty solid generic 60lb injector tune. check out OTTPerformance.com. They can get you a great price on injectors, harness, and if you can find someone local with HPT, they'll e-mail you a tune that you can upload and go from there.
Thanks and another thing im on the second clutch with 20k on it. the first went out before i bought the car used, made the dealer put a new one in 3 days after buying it but its already slippin hella bad but only on the streets but not at the track.
Cptnslo
Sep 24, 2015 09:32 AM
