Help with no start.
Help with no start.
So I just disassembled the supercharger and intake manifold to clean the laminova cores. I just put everything back together and now the vehicle just cranks and doesn’t turn over.
no CEL I plugged everything in where it’s supposed to go and I tried to start it but it just cranks and cranks
thanks in advance
thanks in advance
I am not envious of you right now.
I will say that it is becoming a rather common occurrence for the ground wire to cause a no-start.
The test for that is to hot wire the starter relay - if the ground wire is bad you can ground directly from the relay and if it starts, you've found your culprit.
It took me a long time to get to this solution.
but!!!
Before you dig out that wire end;
first verify via the starter relay that this is your problem - if you ground out the negative end of the starter relay, and it does nothing, this is not your problem.
Now that I am re-reading the first post, it looks like my post(s) were probably of no use;
I am guessing that an ignition plug wasn't correctly coupled or something like that.
Supercharged06SS
Jun 21, 2014 11:42 PM
