Help with no start.
Old Dec 4, 2023 | 12:37 PM
Mike C's Avatar
Help with no start.
So I just disassembled the supercharger and intake manifold to clean the laminova cores. I just put everything back together and now the vehicle just cranks and doesn’t turn over.
no CEL I plugged everything in where it’s supposed to go and I tried to start it but it just cranks and cranks
thanks in advance
Old Dec 11, 2023 | 04:43 PM
soundjunky's Avatar
I am not envious of you right now.
I will say that it is becoming a rather common occurrence for the ground wire to cause a no-start.
The test for that is to hot wire the starter relay - if the ground wire is bad you can ground directly from the relay and if it starts, you've found your culprit.
It took me a long time to get to this solution.
Old Dec 21, 2023 | 11:37 AM
Micro's Avatar
Which ground wire did you end up replacing that solved your issue?
Old Dec 21, 2023 | 11:47 AM
soundjunky's Avatar
please refer to my other thread.
Old Dec 21, 2023 | 11:49 AM
soundjunky's Avatar
but!!!
Before you dig out that wire end;
first verify via the starter relay that this is your problem - if you ground out the negative end of the starter relay, and it does nothing, this is not your problem.
Old Feb 15, 2024 | 08:23 AM
AinsleySutton's Avatar
Any update?
Spoiler
Old Feb 15, 2024 | 10:58 AM
soundjunky's Avatar
Now that I am re-reading the first post, it looks like my post(s) were probably of no use;
I am guessing that an ignition plug wasn't correctly coupled or something like that.
Supercharged06SS
Jun 21, 2014 11:42 PM
codygoofy
May 14, 2010 12:47 AM
rico
Feb 8, 2010 09:46 AM
SS-=MKR=-SS
Dec 22, 2006 10:16 PM
SS-=MKR=-SS
Dec 22, 2006 03:40 PM
