Help with picking stage kits
Old Mar 5, 2006 | 02:59 PM
Badmunky's Avatar
Originally Posted by 06_Cobalt_SS_SC
I want to do some stage kits for my 06 ss sc.Please tell me where I can purchase these kits.and if anyone knows how to splice in a performance module into the Intake Air Temperature Sensor,or where that sensor is,please email me. mtr111685@verizon.net
thanks alot for the help
CHEAP senser mod AKA a .40 cent rsistor will not work on this car. And should not be used on any car. It gives no gain at all as the PCM corrects for this after about 10 sec.
Wait till the end of the month and get a stage 2 kit from the dealer.
Later
Old Mar 5, 2006 | 03:15 PM
Bad06SS's Avatar
You don't have to listen to me. But the stock valve springs are "done" at 6800 rpm's, according to a very reliable source. I did read somewhere that the stage 2 might raise it to 6700 rpm's, but that won't do much. Again, you don't have to take my word for it, wait and see.
Old Mar 5, 2006 | 03:48 PM
FAST06SS's Avatar
Originally Posted by Darksun280
well shows how much you know since theres a member with a 2.4 that just got a reflash and they rasied his limiter to 7000 go find the post. And since both cars use the same springs i would think were good.
You can't compare an NA car to a Forced Induction car. The pressure on the valves and springs is higher in the SC car vs the NA car so the lack of valvespring pressure will be more apparant in the sc application. Now add smaller pullys and the higer boost pressure and you make the springs even more of an issue. Think about it for a minute The valvespring has to "pull" the valve closed against the positive pressure that is constantlt trying to open it! Common sense!
Old Mar 5, 2006 | 06:48 PM
03gobluecobra's Avatar
I heard that it was only done at that RPM when using a big cam. And if you look at the dyno posted of the stage kits from GM, the redline goes to 7000 rpm. Also, I heard that the solstice uses the same springs, and goes to 7000 rpms, although with a different cam.
Old Mar 6, 2006 | 03:43 AM
SilverSS/SC's Avatar
And , furthermore ....GMMP would not raise the rev limit if the springs could not take it . They would have done a completely overkill durability cycle test . Since the kits are warrantied , it would be absolute suicide to GM to raise the limiter on all these cars and have them return limping into the service bay with a broken valvespring . Their legal dept. never woulda let it happen
Old Mar 7, 2006 | 12:44 AM
SS4LIfe's Avatar
i was going to order the intense kit and when the GM kits came out just get a stg 2 reflash and us the maf t to tune it even more.
Do you think they will sell just the reflash.
Old Mar 7, 2006 | 11:00 PM
uhcougar08's Avatar
OK....I am an idiot, but what is a reflash yall talk about? And does this come with the stage 1 or stage 2?
Old Mar 7, 2006 | 11:19 PM
memphisr24's Avatar
It comes with both stages. It's pretty much "updated" information in your computer chip (from what my brain seems to think). Like a computer, going from windows 98 to xp. XP will have better performance, more options, easier to use, etc. The reflash will dump more fuel into the engine thus allowing us to make more boost and horsepower safely.
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
