help pleaseee
Old Jul 10, 2010 | 04:25 PM
DEZZIE41's Avatar
Exclamation help pleaseee
got a aem wideband today installed it and at ideal it reads 14.7-15.3 bouncing around then at WOT i get 3 dots on the screen and when i left off the gas on the high way is this working rite or is something messed up please help thanks
Old Jul 10, 2010 | 04:31 PM
SupaCharged06's Avatar
Bad connection?
Old Jul 10, 2010 | 09:49 PM
ziggity's Avatar
Does it stay 3 dots when u go WOT?... and yeah it will do that on the highway when u let off the gas the cars cutting off fuel
Old Jul 10, 2010 | 09:53 PM
BLAZIN07SS's Avatar
I'm too JDM for you
ummm...something is not right. when it goes to those "---" 3 dash marks it means that it is too lean for the wideband to read
Old Jul 10, 2010 | 10:47 PM
DEZZIE41's Avatar
o well im getting a tune it 2 weeks will that help iut
Old Jul 11, 2010 | 12:08 AM
SunburstSS's Avatar
kk here's how mine works...
cruising : bounces between 14 and 16
WOT : 11.6-11.8 " OTTP Comanded AFR "
When I'm Not Stepping On The Gas : --- Three Dashes Coz The Fuel Shuts Off Or It's Too Lean For The Wideband To Read....
If Ur Seeing --- On WOT Then U Got A Problem
Old Jul 11, 2010 | 07:07 AM
DEZZIE41's Avatar
On wot it is in the mid 14s
Old Jul 11, 2010 | 07:14 AM
Cherry GT's Avatar
It should NOT be near 14 at WOT PERIOD !
That will ruin your engine.
The afr will bounce around while in closed loop, its the oxygen sensor searching for stoich.
Yes sometimes when you release the throttle you might see the --- on the AEM screen.
All sounds normal to me, except the 14 @ WOT, that needs addressed when tuning.
Old Jul 11, 2010 | 08:13 AM
SunburstSS's Avatar
hollly shyt....mid 14's something is wrong :x hmmm ur gauge might be bad ionno but mid 14's is a garaunteed blown engine :x
Old Jul 11, 2010 | 09:46 AM
QuickSilver_SS's Avatar
Could it be running that lean because of the aem intake and the car being stock ?? I got they odd lean code when i was tottally stock with just the air box mod. But once i got the GM STG II installed it has never had a lean code in over a year in a half yet again. Just a thought ?
Old Jul 11, 2010 | 09:56 AM
SunburstSS's Avatar
an intake will cause it to run a little bit lean but not that much...i hope somebody else will chime in on this as well
Old Jul 11, 2010 | 10:01 AM
MSHETZ's Avatar
drop the o2 sensor on the ground by mistake?
Old Jul 11, 2010 | 10:07 AM
NVMYCOBALTSS's Avatar
If your running the S2 tune and the mods in your sig, you shouldn't be anywhere near the 14afr at wot. more around 10.1 - 10.3 depending on the weather.
I think that it was said here before, but the gauge will read --- when the reading exceeds the range that it will display. I think the gauge range is 10 - 18 afr. so at WOT if the afr is 9.9, the gauge will read ---.
Old Jul 11, 2010 | 10:54 AM
At this piont he is tottally stock other then the aem intake and wide band. He doesn't have stage two installed yet.
Old Jul 11, 2010 | 11:40 AM
Gotcha, I read your sig and thought it was his.... oops!
Old Jul 11, 2010 | 03:34 PM
DEZZIE41's Avatar
so something is wrong with my car then
Old Jul 11, 2010 | 04:58 PM
I would say so. Maybe were wrong. But thats a pretty wacked out afr for a stock car with just an AEM intake. Im no expert, But id have that looked at for sure to make sure its not or why it is running that lean.
PyroMechanic
May 21, 2014 12:15 PM
aleyluedtke
May 29, 2012 10:49 AM
kgg5
Jan 12, 2012 09:29 AM
09TcSedan
Dec 20, 2011 05:33 PM
DCOBALTSS
Feb 28, 2011 10:43 PM
