Help.. Reverse Issue..
Old Feb 3, 2013 | 04:39 PM
marth617's Avatar
Hello Everyone,
I just want to know if anyone ever experienced a problem like this before in the 2.0 SS/SC.
So i upgraded my clutch to the GMPP clutch kit & flywheel and also got the lnf shifter bracket.
After installing the parts I notice my shifts needed to be re-adjusted so i re-adjusted and now all the gears shifts fine 1-5 without any issues but the car will not go in reverse (yes I am pulling up the reverse lockout on the shifter) but it will NOT in place, BUT when i turn off the car and put the shifter in reverse it will go in without any problem there i would have to turn on the car while in reverse to reverse my car...
I rechecked the shift linkage and the shifter bracket multiple times and everything seems in place correctly. But when the car is on it will not allow me to put in reverse vs. when the car is off it will go in fine.
Any ideas on what i may need to buy or try next? I am using the stock shifter. Any suggestions would be a GREAT amount of help.
Thank you
Old Feb 3, 2013 | 04:48 PM
mrbelvedere's Avatar
try posting in the problems and service section/ cable adj air in the system
Old Feb 3, 2013 | 04:49 PM
marth617's Avatar
ok ill post there
royce777
Sep 28, 2015 07:11 AM
brett.higgins3
Sep 24, 2015 09:51 AM
ashalle2
Sep 16, 2015 10:36 PM
bobbob160
Sep 15, 2015 11:31 PM
TrevorB
Sep 14, 2015 03:59 PM
