Help with spacer
Old Mar 15, 2011 | 06:00 PM
goldchain69's Avatar
Help with spacer
I am trying to install a throttle body spacer and I am not able to get it to fit the throttle body is hitting on the AC line. Am I doing something wrong?
Old Mar 15, 2011 | 10:53 PM
stonny9's Avatar
If the spacer isnt being used for a place to spray meth/nitrous or for the ls4 tb blade clearance then it is a waste. The tb should not hit the a/c line. Sounds like maybe you have the orientation wrong or something. Also if the spacer is too thick then you wont have enough threads on the bolt to correctly/safetly screw it back in. I would saay at least 4-5 turns on the bolts before they get tight.
Old Mar 16, 2011 | 11:19 PM
I'm using the spacer for meth and I have longer bolts to mount it but the part of te throttle body that the plug plugs into is hitting the ac line. Can anyone with a spacer on a ss/sc please chime in.
Old Mar 17, 2011 | 12:03 AM
Bluelightning's Avatar
Got Bewst?
I have an OTTP spacer for my meth and i have zero clearance issues. Maybe take a pic and post it to see if something isn't right. Who's spacer is it?
Old Mar 17, 2011 | 12:18 AM
stonny9's Avatar
I will look tomorrow. I have a homemade spacer for clearance on my ls4 tb.
SmitBag
Sep 7, 2016 08:05 AM
chefhhr
Oct 26, 2015 10:36 PM
TotalChaos
Oct 14, 2015 06:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
