Help! stage 2 belt troubles
Old Dec 28, 2009 | 06:32 PM
LaserblueSS's Avatar
hey guys, i have tried searching and i even looked at the pictures on the "how to" for installing stage 2 but i cant seem to figure out how to relax the tension on the belt so that i can get it over the supercharger pulley. this is the last thing i have to do before it runs again so pleaseeeee help! pics of what to push down / turn / pry would be amazing. thanks in advance
bump. cmon pleeeaaase somebody has to know this
back to the top
Last edited by LaserblueSS; Dec 28, 2009 at 06:32 PM. Reason: Automerged Doublepost
BLAZIN07SS's Avatar
I'm too JDM for you
you see the pulley just to the left of the SC pulley? that is your belt tensioner. from a top view, right behind the pulley, you are going to see a tab. if i remember correctly, a 15mm(could be bigger or smaller) open ended wrench will fit over this tab, push forward and it will relieve the belt tension
Old Dec 28, 2009 | 06:38 PM
much appreciated. this has been the biggest knuckle busting pain in the ass thing to install
Old Dec 28, 2009 | 07:13 PM
qwikredline's Avatar
blazing is a helpful guy, its 15mm and it takes some care and a little prybar assistance, as you have to press to the rear of the car and down to properly release tensions without busting your knuckles and slipping off. Once you have done it a few times its ez. Until then its a pita
blazing is a helpful guy, its 15mm for sure and it takes some care and a little prybar assistance, as you have to press the tensioner back to the rear of the car and down to properly release tension without busting your knuckles and slipping off. Once you have done it a few times its ez. Until then its a pita
Last edited by qwikredline; Dec 28, 2009 at 07:13 PM. Reason: Automerged Doublepost
Old Dec 28, 2009 | 07:37 PM
i have been trying to get this for the past hour without any luck. this seems fuggin impossible to put on.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
