help with timing
Old Jan 27, 2008 | 12:12 PM
bigjoe25's Avatar
help with timing
i have a 2005 ss/sc and i need help with timing the engine the paperwork i have on it dosent make sense so if someone could help it would be great
Old Jan 27, 2008 | 12:13 PM
articzap's Avatar
Why do you need to time it?
Old Jan 27, 2008 | 12:14 PM
bigjoe25's Avatar
because i am rebuilding the engine
Old Jan 27, 2008 | 12:16 PM
articzap's Avatar
Did you make marks on cam gears and crank pulley when you took it apart? If you did you can just line those up and your good to go.
Old Jan 27, 2008 | 12:19 PM
bigjoe25's Avatar
yes there is marks but the paper i have with the steps dont add up isent it sapoused to line back up after 2 full turns of the engine on the comp strock (no not the colord links just the timing marks}
Old Jan 27, 2008 | 12:22 PM
articzap's Avatar
2 full turns of the crank = 1 turn for the cams.
Old Jan 27, 2008 | 02:12 PM
2K5SS/SC?'s Avatar
Damn it's been so long since I did it that I've forgot. Is the engine out of the car?
If so, you can use the colored links on the chain to line it up. The LSJ build book that is stickied on the redline forums has the info in it that you need. Basically the colored links won't line up until after a ton of rotations again just like you said.
I believe the cam gear marks will be 180 out for one full turn of the crank and line back up on the second full turn. Make sure you double check it though and have a friend handy to turn the wrenches on the cams to align the gears while you put the chain on and ensure the crank pulley doesn't come off the TDC mark.
Old Jan 27, 2008 | 03:38 PM
bigjoe25's Avatar
hay thanks for the info and can you give me a link to the build book on the redline forums thanks
Old Jan 27, 2008 | 10:49 PM
2K5SS/SC?'s Avatar
How about a link directly to all the GM build books instead?
If you scroll down on the page the links for the 300+ecotec build is there too which is also helpful about some details, but I think the info you want is in the LSJ books.
http://www.gmperformancedivision.com..._articles.aspx
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
