Ok car is on dyno as we speak, I don't know how you guys are running so much timing, after 15 degrees it starts to ping
Fuel
I run 26* on E85 |
None here bro, were smoothing it out, it's actually a lot better on that 3.0" do you still want that pulley bro?
That's why E is the magic sause :)
Lol it would be nice if E was readily available here
Well, what did it make this time?
Water methanol injection is the other option if e85 isn't available.
Did it make any more power with the 3"
I made 290 and 247
Thats about average for your setup.
Yea, still was hoping for a bit more but whatever it's running strong not dying and not falling on its face at high rpms so I'm happy
That's pretty substantial for a 15* max
If you run methanol you can bring those torque numbers up substantially and roughly around 320-330whp Or run a race gas tune |
15* timing sounds like ur getting some shitty 93 gas, I was having same issue with shell it was getting knock past 16* up top switch to another station and was able to run lil more timing.
Hmm I hadn't thought of that, both times before running it on the dyno I filled it up at the Shell station, bastard lie about having the best gas
Originally Posted by Vander Nars
(Post 6985076)
Originally Posted by 100% METH
(Post 6985209)
19-21 psi on a 3" pulley will do that
