Help TVS tuning
Old Mar 17, 2013 | 02:25 PM
Mendomar06's Avatar
Help TVS tuning
I was wondering I'd someone could shed some light, car is on the dyno and hptuners is open, at 6k rpm the car leans out and falls on its ass, guy tuning says the maf sensor isn't reading past 10k htz but it goes up to 11,100k htz
Old Mar 17, 2013 | 02:37 PM
Bad-A-SS's Avatar
Should have posted this in the tuning section. Maybe area can chime in on this for you. Get am mod to move it. Thanks
Old Mar 17, 2013 | 02:57 PM
574's Avatar
574
What pulley, fuel and injectors
Old Mar 17, 2013 | 03:06 PM
Mendomar06's Avatar
Ok, hopefully mod will move it, and zzp's 80lbs injectors 2.6 pulley
Old Mar 17, 2013 | 03:19 PM
574's Avatar
574
On dino fuel?
Old Mar 17, 2013 | 03:59 PM
Mendomar06's Avatar
No premium n it's only making 270hp and 240 trq
Old Mar 17, 2013 | 05:03 PM
nhanson's Avatar
What brand dyno?
Old Mar 17, 2013 | 05:16 PM
Mendomar06's Avatar
Dyno Jet if I'm not mistaken, we got the MAF issue figured out and it runs smoothly I'm just disappointed with the power.
Old Mar 17, 2013 | 05:20 PM
574's Avatar
574
What was wrong with the maf
Old Mar 17, 2013 | 05:21 PM
Tjolley's Avatar
Wat r u iat2 temps
Old Mar 17, 2013 | 05:22 PM
Mendomar06's Avatar
It wasn't reading properly so after 6k it would rich out and drop hp almost to 100hp but he figured it out, it was something in the tune.
IATs post charger are 131 and are pretty constant
Last edited by Mendomar06; Mar 17, 2013 at 05:22 PM. Reason: Automerged Doublepost
Old Mar 17, 2013 | 08:13 PM
nhanson's Avatar
Are you pushing enough timing?
Old Mar 17, 2013 | 08:21 PM
Chevycobaltss3's Avatar
Well in diag he can up the hertz to be maxed around 16k. Now if the car leans out and he's going based off afr error add fuel. It is honestly not difficult but in wot your feeling is based off your prest calculated fueling so if it goes lean then he needs to up the calibrations.
Old Mar 17, 2013 | 08:33 PM
Vander Nars's Avatar
270 is good for 93 gas only, if u want more gonna need meth or e85.
Old Mar 17, 2013 | 08:35 PM
mrbelvedere's Avatar
or raise the pulley up
Old Mar 17, 2013 | 08:37 PM
Sunburst_SS's Avatar
just under 289 and 260 tq on mine......that was with stock exhaust and no cooling mods.....it opened up a LOT more after the 3" exhaust and some cooling mods.
Old Mar 17, 2013 | 08:44 PM
Mendomar06's Avatar
Something is off, I have ZZP Long Tube Headers and DP, Option B, Dual Pass, Secondary HE, 80# Injectors, 2.6 Pulley, 3" intake so what am I missing other than maybe an LS4 TB
Old Mar 17, 2013 | 08:45 PM
oh, an that was one a 2.9" pulley
Old Mar 17, 2013 | 09:00 PM
574's Avatar
574
I think you may be missing a good tuner
Old Mar 17, 2013 | 09:24 PM
Mendomar06's Avatar
Old Mar 17, 2013 | 09:39 PM
what plug and gap are you running?
Old Mar 17, 2013 | 09:40 PM
Mendomar06's Avatar
Stage 2 colder plugs ngks gapped at .30
Old Mar 17, 2013 | 09:47 PM
it's hard to say without seeing a datalog and the tune......but it's possible it could be spark blow out....maybe try tightening up the gap just a little more.
Old Mar 17, 2013 | 09:59 PM
Mendomar06's Avatar
Do I need to upgrade my MAF sensor?
Old Mar 17, 2013 | 10:02 PM
doubt it......but it is hard to say what is going on without seeing some data
