Help w/TB Spacer & CAI Fitment PLEASE!!!
Hey guys, i bought the throttle body spacer with side methanol tap from sjschafer (looks great btw!!) and i got me a injen cold air intake through turbo tech racing (awesome vendor!!) and i cannot get these 2 to work with each other. when i install the spacer it makes the throttle body go 1/2" closer to the intake at an angle, so when i try to connect the black rubber connector that goes from the actual throttle body to the injen intake not only is it short but the angle is off so there is a big gap between the 2...i tried multiple things and could not get it to work so how are you guys getting it to fit correctly? i figured i could go to autozone and find a connector to work but they didnt have jack ****. any ideas? and pictures would be awesome too!!! Thanks!
didnt you already make a thread about this?
at angle you said... it pushes out equal on all sides.... did you install it right?
Last edited by ColeJJones; Jul 14, 2008 at 03:45 PM. Reason: Automerged Doublepost
bump. any ideas guys? pictures?
