Here's a ?tion for ya.
Old Jun 1, 2006 | 01:08 PM
trobin44's Avatar
Does rim size have an effect on dyno results? What about tire profile, does it play a part also?
Just curious.
Old Jun 1, 2006 | 01:11 PM
3fo893013L's Avatar
rim size will only play a part in a top speed trap if the tires bigger then OEM.
I.E A bigger tire/rim combo will negate any HP add ons by 3% or less but offer better top end over acceleration.
In reality I doubt you will see a big difference in loss of power with a bigger rim unless your going over 3 inches over stock. That's just me.
Old Jun 2, 2006 | 12:40 PM
trobin44's Avatar
Sweet answer. Thank you. It's just a curious question to throw out there just to see the responses I get.
Thanks again for taking the time to answer.
Old Jun 2, 2006 | 12:42 PM
BLKSS's Avatar
Hes right, I could see a little difference considering wheel weight but very little it wouldnt be noticeable.
Old Jun 2, 2006 | 01:39 PM
Tomtwtwtw's Avatar
Bigger rims may hurt your accel numbers due to the extra rotating mass, but that's not what the dyno measures. You should see no change on chart.
Old Jun 2, 2006 | 01:47 PM
player_1's Avatar
it's not so much that bigger rims might hurt you, it's heavier rims that will hurt you on a dyno. ( most cases a bigger rims is heavier, I just wanted to straight that out tho )
Old Jun 3, 2006 | 10:40 AM
trobin44's Avatar
Thanks Player.
Old Jun 3, 2006 | 10:59 AM
Chizzap30's Avatar
What about rim that is same as stock, but wider by say half an inch to inch and a half?
Old Jun 4, 2006 | 12:06 PM
trobin44's Avatar
Same outcome as above I would think.
06blackg85ss
83
Jan 18, 2017 04:35 AM
Death Dealer
Aug 24, 2008 11:26 AM
Death Dealer
Jun 29, 2008 07:51 AM
Death Dealer
Sep 27, 2006 06:04 PM
Death Dealer
Sep 27, 2006 04:40 PM
