Hey guys need some help/advice
Old Feb 8, 2009 | 01:47 PM
FZWCobalt_09's Avatar
im on my way to my uncles house. I pull out of the naighborhood revved first out to 4k just trying to get out there quick cuz of oncoming cars. Then i notice the check engine light. i let my sis hold the wheel while i pull out the scanner. i pull the coad and its lean in cylender bank one. so i swapped plugs from 1st cyl to 2nd cyl to see if it was a plug probblem and it threw the coad again in cylender one. So idk what it could be. Ajss is giving me a 3.3 until i can get this figured out. Thanks. Mods are in sig.
Old Feb 8, 2009 | 01:50 PM
RooTBeeR's Avatar
Ok, if it says its lean then your spark isn't the prob. It's most likely your #1 injector...so it could be faulty and have died, or it is clogged.
Old Feb 8, 2009 | 01:53 PM
tere brand new 42s from zzp
Old Feb 8, 2009 | 01:56 PM
RooTBeeR's Avatar
well maybe check the wiring harness to make sure they are still connected properly
Old Feb 8, 2009 | 01:58 PM
Bika's Avatar
Fail Less.
gm tune + 2.9" could = lean fuel trim. Or if you have an aftermarket intake
Old Feb 8, 2009 | 02:28 PM
Maxim_X's Avatar
Bank one is not cylinder one. They use bank one and bank two to show codes like that since we have an inline motor we only have one bank so they call it bank one. It is just a lean code... do you have a wideband??
Old Feb 8, 2009 | 02:37 PM
No i dont have a wideband. the coad is p1071
i have a airbox mod
Last edited by FZWCobalt_09; Feb 8, 2009 at 02:37 PM. Reason: Automerged Doublepost
Old Feb 8, 2009 | 02:53 PM
kburgess04's Avatar
remember just because it is new doesnt mean its good. could be faulty. pull the fuel rail and injectors clean them out. its an easy job
Old Feb 8, 2009 | 04:18 PM
i figured it out it was a massive vaccume leak
Old Feb 8, 2009 | 05:10 PM
99mustanggt's Avatar
Wow way to go, so when are we doing my headlights and wheels
Old Feb 8, 2009 | 07:51 PM
never
bigdeertz
Nov 17, 2016 09:41 AM
Dirtybutwhole
Sep 26, 2015 06:53 PM
roth
Sep 26, 2015 12:16 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
