hid issue again
Old Feb 7, 2011 | 05:01 PM
DEZZIE41's Avatar
hid issue again
so driving tonight hids working mint, then right sdie went out, wtf right, so then i flicked my highs on then back to low(which are hid). after flicking from high to low both low hids were on again any ideas?
Old Feb 7, 2011 | 05:02 PM
Turbalt2010's Avatar
did you get the relay harness?
Old Feb 7, 2011 | 05:03 PM
DEZZIE41's Avatar
nop..i cant c a relay harness making it help..if only one light went out then had to flick it and then back on
Old Feb 7, 2011 | 05:33 PM
3de3gre33dk3's Avatar
Relay harness keeps that from happening. It pulls alot of power to ignite the HID bulb and the factory wiring isn't a small enough gauge to do both light at the same time always.
Old Feb 7, 2011 | 05:35 PM
DEZZIE41's Avatar
fml...also how do i adjust my head lights they seem to be spread out to much
Old Feb 7, 2011 | 05:40 PM
BlackARCA06's Avatar
Yea you need a relay Harness. And you can only adjust them up and down.
Old Feb 7, 2011 | 05:41 PM
DEZZIE41's Avatar
damm it lol where could i get a harness at
Old Feb 7, 2011 | 05:44 PM
CobaltVenomSS's Avatar
yepppp u need relay... my first set did what urs are doing then i got a new set with relay and no problems
Old Feb 7, 2011 | 06:15 PM
DEZZIE41's Avatar
so i have to buy a hole new set ur saying
Old Feb 7, 2011 | 06:23 PM
keiserX13's Avatar
Mine did this WITH A RELAY
ended up getting the ballast replaced under warranty
Old Feb 7, 2011 | 06:26 PM
DEZZIE41's Avatar
so wth do i do lol
Old Feb 7, 2011 | 06:35 PM
mkulrey13's Avatar
Eh, your car just doesnt like cool lights :P
Old Feb 7, 2011 | 06:37 PM
DEZZIE41's Avatar
thats not helping lol.. just werid that one side kicked off then i flicked my lights then they both worked
Old Feb 7, 2011 | 10:22 PM
My first set did it with no relay, but after a while it went away. Then I got into a accident and had to get a whole HID set, after a couple months my lights would flicker when the would come on, ordered a relay and it fixed the problem. Not running a relay is bad for your headlight wiring harness.
Old Feb 7, 2011 | 10:25 PM
keiserX13's Avatar
Switch the ballast and see if it stays with the ballast or the bulb. Then contact your vendor from there...
My car doesn't like me in general...
Old Feb 8, 2011 | 09:09 AM
srt-10's Avatar
dezzie that same thing happend to me when james installed my HID's. Your have to either get GM to turn off your DRL or wire it up as per the diagram i showed you. Its not that hard. All you do is put little connectors on each wire and they slide onto the relay. If i could do it, you can do it. And trust me, i hate wiring ****.
Old Feb 8, 2011 | 10:34 AM
DRL fuse also?
Old Feb 8, 2011 | 02:15 PM
srt-10's Avatar
if a dealership turns the DRL theres no need to remove the fuse, then again, theres no need to have it either. That being said, most dealerships are dicks and wont turn it off in canada since its illegal to have no DRL during the day, or at least thats the excuse 3 dealerships gave me for my truck.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
