High IAT2's...HELP!!!
Old Jun 2, 2012 | 03:00 AM
kdub1492's Avatar
Long story short I have Option B, S3 H/E, dual pass. Had m62 on my car, drove to Kentucky and IAT2's were at about 80-85 all the way there Ambient about 70. Get my TVS put on and my IAT2's skyrocket. We think that its my IC pump so I go home and order a new one, put it on and still have high IAT2's. Was driving home today and it was 50* out and IAT2's were at 100*...like I said IC pump is working because I can see coolant flowing in and out of the Option B tank. What else could it be? Thanks in advance!
Old Jun 2, 2012 | 03:28 AM
Vander Nars's Avatar
umm try the phenolic spacer, but I thought IAT2 of 100 was fine, when I got tuned my IAT2 was 125 and james said that was fine.
Old Jun 2, 2012 | 03:41 AM
100% METH's Avatar
Did you hook up the bypass correctly? If your bypsss valve is always closed, theres your problem. Make sure your vacuum lines for the bypass are not crossed
Old Jun 2, 2012 | 10:43 AM
rivaladore's Avatar
^^^this. And did you figure out the problems with those codes in the other thread, was it the emmissions fuse like I said?
Old Jun 2, 2012 | 11:19 AM
kdub1492's Avatar
Thanks guys I'm going to check that! And yes it was the fuse, never seen a fuse blow the way it did haha it was like shattered inside. But I'm guessing it was from my o2 sensor having a open wire and hitting against metal or something
Old Jun 2, 2012 | 01:29 PM
kdub1492's Avatar
What am I supposed to look for with the boost bypass valve? Is it supposed to be moving at idle or something? If someone could give me so insight that would be awesome!
Old Jun 2, 2012 | 01:39 PM
100% METH's Avatar
When the car is off the arm on the bypass should be pulled out
, closing the valve.
When the car is on at idle, it should be sucked in, opening the valve.
Old Jun 2, 2012 | 02:57 PM
bluebalt07's Avatar
Make sure the top nipple on your bypass is the one connected to the TVS
Old Jun 2, 2012 | 11:49 PM
kdub1492's Avatar
Ok so the bypass valve works just fine. Idk what to check now. System is bled, there is no air coming out of my bleeder line for the option b. anything else to check? IAT2's are on average about 50* over ambient
Old Jun 3, 2012 | 01:48 AM
rivaladore's Avatar
Unbolt the option b from the passenger side strut mount and hold it as high as the hoses will let you. This will help kick start the bleeding process if there's a big air bubble. Maybe the system isn't really bled and the movement you think you're seeing is just vibrations from the engine.
toysareforboys
Nov 17, 2015 05:22 AM
no_ss
Oct 18, 2015 11:58 PM
camaromanss1992
Oct 1, 2015 10:51 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
