High IAT2s, need help
Old May 6, 2010 | 02:26 AM
Mclovin23's Avatar
did a couple pull tonight after working on the air to fuel. doing some data logs and everything was going fine and all of a sudden i hit 6 degrees of knock. the a/f was fine but then we saw the IAT2s were over 200. i recently installed dual pass and option b. i dont know if my pump is bad or if i hooked up the dual pass wrong. can someone give me specifics on how it should be. yes i have searched but im just making sure that its not my own stupid error.
Old May 6, 2010 | 02:27 AM
sundevil07's Avatar
did you flip the laminovas?
check the h/e pump
Old May 6, 2010 | 02:31 AM
Mclovin23's Avatar
yeah i did swap the laminovas for sure. what is the H/E pump? is that the intercooler pump
Old May 6, 2010 | 02:35 AM
sundevil07's Avatar
yes it is, check to see if waters moving in the reservoir
bet its not
Old May 6, 2010 | 02:44 AM
BCM's Avatar
BCM
Sounds like your intercooler pump isn't working, try tapping it with a hammer or something. That might get it to start going again. for now anyway..
Old May 6, 2010 | 02:48 AM
Mclovin23's Avatar
ok i'll check. its always something with this damn thing. lol. question: if the key is turned on should the pump turn on or only when its running? if i have my buddy at a shop use the gm tool to start the pump and it starts pumping could i assume its fine? thanks for the help so far guys
Old May 6, 2010 | 02:59 AM
sundevil07's Avatar
stock it will turn on 10 seconds after the car has started
Old May 6, 2010 | 08:10 AM
Sizzle06's Avatar
With hp tuners you can have the pump turn on by just putting the key in the run position.
Old May 6, 2010 | 08:57 AM
NexTnmE's Avatar
Damn. My IAT2's were never over 155* when I had a bad I/C pump. If you bang on both ends of the I/C pump with a hammer, like stated before, it will work for a while longer, but you should look into getting it replaced. I would also retrace your steps with the dual pass and opt.b... that's way too high...
Old May 6, 2010 | 09:23 AM
skatin_boarding's Avatar
^^^ What he said. Also double check all your coolant hoses for kinks. I had a nasty one I missed. Be easy on the car till you figure this out.
Old May 6, 2010 | 09:32 AM
SunburstSS's Avatar
stupid question & sorry for thread jacking do u need hptuners to log ur iat2 temps ? or is there another way to do it ?
Old May 6, 2010 | 10:32 AM
bmb17's Avatar
You can get an Aeroforce interceptor gauge to monitor you iat2 temps.
Old May 6, 2010 | 10:42 AM
Mclovin23's Avatar
Hey sizzle, where in hptuners can i get it to come on with key in the on position. cant hear **** when the car is started. lol
Old May 6, 2010 | 10:48 AM
roderick's Avatar
you need some meth to cool that temp.
Old May 6, 2010 | 11:03 AM
Mclovin23's Avatar
oh for sure man. lol. but this isnt normal. a couple pulls with TVS on stock pulley dual pass, and option B. somethings not right
Old May 6, 2010 | 11:10 AM
Off the top of my head I think its Engine> Torque Management> Superchager and I think there is a little section with the ic pump settings.
Old May 6, 2010 | 11:36 AM
Mclovin23's Avatar
i think i saw it but we just changed it from wait 10 seconds to turn on to 1 second. started it up still morning and the option b reservoir was bubbling so i would assume its pumping. i opened the stock filler neck and it started to fill up. does that sound like the pump is ok? i also checked for kinks and my routing. i connected the top and bottom nipples on the dual pass with the top one going to the option b tank and the bottom end going to the pump. them the middle section to the stock H/E. does that sound correct. i also have the bleeder line from the tank to the h/e too.
does anybody bypass the stock filler neck and put a straight hose from the h/e to the middle of the dual pass or should we keep it?
Old May 6, 2010 | 12:07 PM
roderick's Avatar
When I installed my H/e I didnt get all the air bubbles out and my temps after a pull was like 165-170 but after I got the air bubbles out it is now down to like 125-130 so maybe you just got alot of air in your lines.
Old May 6, 2010 | 01:53 PM
Mclovin23's Avatar
i did it about two to three weeks ago so i would assume the air would be out. but it did bubble quit a bit so maybe some got in there. who knows. does my routing sound correct though? what about the filler neck?
well looks like its the pump. it was working right away this morning but when i checked again later today the reservoir was doing nothing and there was nothing in the filler neck like there usually is. i tried hitting it but couldnt get the best angle but still nothing. this ******* blows
Old May 6, 2010 | 03:28 PM
richienolan's Avatar
so which knock do u use cuz they list 3 in the list of things u csn montior on my inceptor, i herd u only watch the 3rd one but not sure and i no what knock is but what causes it
Old May 6, 2010 | 04:30 PM
Yep the third one. If you have opt b you Can get rid of the stock filler neck and run that section to the opt b. then use opt b to fill it up. Maybe you had an air bubble stuck in there and it got really hot.
Old May 6, 2010 | 10:44 PM
cool thanks so i have no knock but i get some miss fires what gives im bone stock expect for a drope in filter
Old May 6, 2010 | 11:31 PM
rnjmur's Avatar
You will always get a few misfires here and there.
Old May 7, 2010 | 12:51 PM
ok will i get like 2 and then every now and then it jumps to 6 or 8 i have even seen 12 but seems like it does it when i push the clutch in and am rooling to a stop like parking or something like that ??? and thing i shoud be worried about ??
Old May 7, 2010 | 08:11 PM
rnjmur's Avatar
I wouldn't worry about it. My LSJ used to get random misfires and knock when I used to clutch or at idle, that is until I tuned it. Once tuned I hardly ever saw any misfires or knock at clutch presses or idle.
