High IAT2s, need help
Old May 7, 2010 | 10:11 PM
richienolan's Avatar
ok kool thanks for the help
Old May 8, 2010 | 02:32 PM
Mclovin23's Avatar
Originally Posted by skatin_boarding
Yep the third one. If you have opt b you Can get rid of the stock filler neck and run that section to the opt b. then use opt b to fill it up. Maybe you had an air bubble stuck in there and it got really hot.
yeah thats what i thought. but the good thing about that filler neck is i can see the fluid go through when the pump is actually working. we hit it witha hammer and it came on. lol.
i ordered the bosch intercooler pump so i should get that tuesday. should be an easy install. foes anyone had any bad or good experiences with the bosch pump?
Old May 17, 2010 | 11:07 PM
so when my iat is at 60 andmy iat2 are at 100 to 120 id say my ic is not working right ??
Old May 18, 2010 | 12:01 AM
skatin_boarding's Avatar
Really I wouldnt worry about a 120* iat2.
Old May 18, 2010 | 02:25 AM
Mclovin23's Avatar
i wish mine were that low. your fine at 120
Old May 18, 2010 | 07:45 AM
really i thought the 2 numbers should stay a little closer together then that
Old May 18, 2010 | 10:58 AM
rnjmur's Avatar
Depends on your mods. If you are dual pass or bigger/second HE then that is pretty high. When driving on a 60F day my IAT2 would usually be at ~80F, that is with dual pass and opt b w/2.9 pulley.
Old May 18, 2010 | 11:05 AM
StageII07's Avatar
My iat2's get to like 150 right now..i dont have my meth hooked up yet and im wating for my h/e so im crusing around with a half tuned tvs and 80's..lol
Old May 18, 2010 | 03:48 PM
well im all stock so what should my iat2s be
Old May 19, 2010 | 08:55 AM
NexTnmE's Avatar
I've heard as a rule of thumb, 20 degrees over ambient temp is a typical IAT2. Even for stock. But after a WOT pull tho... not too sure.
Found this too...
https://www.cobaltss.net/forums/show...ight=stock+iat
Old May 19, 2010 | 09:16 AM
  #36
well mine seem to be all over the place so i think im going to put my new pump on that i have had for awhile now lol
Old May 19, 2010 | 12:39 PM
  #37
Mclovin23's Avatar
im in the same boat. mine works sometimes and not others. i got the bosch replacement sitting at the shop waiting to go in. i was just waiting for my heat exchanger first.
Old May 25, 2010 | 08:29 AM
  #38
yeah same here lol its been warm up here in cleveland and i seen my iats'2 hit 150 yester day so i need to get my pump on lol
Old May 25, 2010 | 09:41 AM
  #39
NexTnmE's Avatar
On a different note... has anyone changed the coolant to more water than dexcool? Right now I'm running 50/50, the temps are fine, just wondering if I'd benifit from something like 75% water, 25% dexcool?
Old May 25, 2010 | 09:44 AM
  #40
dont know lol
Old May 30, 2010 | 03:35 AM
  #41
87gn06gto07irl's Avatar
Yes you will. I run water and a bottle of chill charger.
Old May 30, 2010 | 03:41 AM
  #42
hawkesb3's Avatar
ya sounds like ic pump too me tap with rubber mallet and run 75 water 25 dex oh ya and get an interceptor cuz repeated runs over 200 iat2s... kaboom
Old May 30, 2010 | 11:14 AM
  #43
rnjmur's Avatar
Water is actually the coolant, so running a higher part water will cool temps more. The dexcool is a lubricant and raises the boiling boint as well as lowering the freezing point. The IC system shouldn't get hot enough to boil, so that isn't an issue. You don't need much lubrication in the IC system either. The only thing you have to watch out for is freezing.
Old May 31, 2010 | 02:41 PM
  #44
ok cool deffently going to run 75 water and 25 dex
toysareforboys
Nov 17, 2015 05:22 AM
no_ss
Oct 18, 2015 11:58 PM
camaromanss1992
Oct 1, 2015 10:51 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
