Squeak/rattle noise from engine
Old May 31, 2010 | 03:10 PM
Bika's Avatar
Fail Less.
Coming home last night I heard what sounded like belt squeak at low rpms, and it gets faster/louder as rpm increases.
I have checked the s/c pulley and it is on securely. the belt is not slipping either.
Now, I assume it is the tensioner pulley... but before I go spend $120 I want to hear some opinions.
Old May 31, 2010 | 03:33 PM
Dainslaif's Avatar
Sounds like tensioner pulley. Mine's been doing that for a while now, you don't need to replace it unless it's failing; that squeaking is just the bearing getting dirty/lacking grease.
As a quick fix, you could try taking it off and put some grease on the bearing. That might fix it for you at a minimal cost.
Old May 31, 2010 | 03:39 PM
chris88z24's Avatar
Take the belt off and spin each pulley by hand and see if it's making any noise.
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DANRICKARD
Oct 1, 2015 12:08 AM
