High Pitched Tick Noise
Old Mar 24, 2012 | 03:27 PM
Slowbalt4life's Avatar
Hey everyone i noticed this a while ago but i decided to post now every morning i start my car up i get a pretty high pitched tick noise coming somewhere near the back of the motor i no its not an exhuast leak because after like 3 minutes or so when the car gets a little hotter it quiets right down you can still hear it when driving but it deffinetly gets quiet at about 3 grand or so you it goes away idk what it is and i couldnt finds any threads on what it could be any thoughts?
Old Mar 24, 2012 | 03:55 PM
dakotaspeir's Avatar
#cobalthoes
mine ticks because its supposed to.
Old Mar 24, 2012 | 04:28 PM
CrateEngineDepot's Avatar
Common problem on cold start ups. This will fix it:
Link
Old Mar 25, 2012 | 01:11 PM
you sure its the timing chain tensioner because i would think that would be more of a slappy noise not a high pitch squeak i did my oil change a month back or so and it quieted down a little bit but like halfway through the oil change it goes back to normal sound again idk if its a sticky valve or what
Old Mar 25, 2012 | 01:22 PM
rivaladore's Avatar
Try tightening down the header bolts. Some people have had a problem with one or two bolts being loose. If not that then I'd go with the tensioner. Try to get a video of the sound for us. Also could be a pinhole leak in the downpipe by the flex section.
Old Mar 25, 2012 | 02:01 PM
Okay I'll go get a video but if it was a hole in the header or dp it wouldn't go away when its warmed up would it?
Old Mar 25, 2012 | 02:36 PM
heres the link to the video:
Cobalt ss high pitch tick noise - YouTube
Old Mar 26, 2012 | 02:03 PM
SS1's Avatar
SS1
the initial sounds sounds like a gasket leak or more of a flex pipe leak beginning specialy when you threw the cam right in there, but then you said it goes away. i have a similar sound at the moment and i havent had time to track it down. i'll probably look at it tonight and get back to ya unless anyone else has a say.
Old Mar 26, 2012 | 02:18 PM
ChargedxSSx's Avatar
it is DEFF. the timing chain tensioner!!!!! same thing happened in my old LS ... easy cheap fix ... until u let it get outta hand ..
Old Mar 26, 2012 | 09:24 PM
You think its the timing chain tensioner? I'll look more into it but if you figure out what it is tonight let me know. The only reason I didn't think it was the tentioner because like I said when I do my oil changes it quieted down for a little bit then it comes back again
Old Mar 26, 2012 | 09:44 PM
mine seemed to do the same thing ... and it sounded worse when it was cold outside ... but until you get inside there .... you will never know 100% ...
Old Mar 26, 2012 | 09:47 PM
05Slowline's Avatar
def something in the block sounds like valvetrain slapping but timing chain tensioner is an easy cheap first step
Old Mar 26, 2012 | 10:41 PM
Yeah I thought it might be a sticky valve or something but would it just go away like that for a little while after changing the oil if it was the timing chain tentionor?
Old Mar 26, 2012 | 10:47 PM
05Slowline's Avatar
couldn't tell ya i never had the timing chain problem going away after changing oil kinda sounds like it would be valvetrain related, i'd take the vc off and see if anything is out of the ordinary.
Old Mar 27, 2012 | 08:16 AM
yeah i was planning on it soon just seeing if anyone else had any related issues
biniecki
Oct 25, 2015 02:23 PM
no_ss
Oct 18, 2015 11:58 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
