Hitting 20Psi at 7k, Is this a little high?
Old Dec 16, 2010 | 09:08 PM
ULWizSS's Avatar
So i finally got the ZZP S3 H/E, 60's, 2.8 pulley and my fronts trans mount installed on the car. Still got the rear trans mount to go.
With the 2.9 pulley i would see a max of around 16.5psi. Just got the 2.8 put on and i am seeing almost 20psi at around 7k. Is this not a little high? I would have guessed 18.
Car is on a stock exhaust with a ZZP 3' Catless DP.
Other than that the S3 H/E from zzp definately helps the car recover faster. Props to them.
Old Dec 16, 2010 | 09:16 PM
Chevycobaltss3's Avatar
Well actually. It seems fine becuz of the cold. If u had a catback I could say,different. And ure altitude has a lot to do with this as well I mean id say most would be 18. Ut if u r using the stock gauge its usually off by lbs. Have ure tuner look into it.
Old Dec 16, 2010 | 09:17 PM
Jaredssbalt's Avatar
I run about 16psi on my 2.8. Once in awhile i hit 17.5.
Old Dec 16, 2010 | 09:20 PM
Are u meaning 2.6 because u r fine. .
Old Dec 16, 2010 | 09:23 PM
ULWizSS's Avatar
Slight typo. Was on a 2.9 and just went to a 2.8. Seeing 20psi with the 2.8.
Old Dec 16, 2010 | 09:30 PM
InfraRedline's Avatar
On stock header and catback on a cold day I could see it being normal
Old Dec 16, 2010 | 09:44 PM
Stone629's Avatar
That is a little higher than normal, but like previously stated, cold air and stock cat-back could be the culprit. Its been dipping into the low 20s here at night, and my boost is staying consistent, around 17-18, same boost as earlier this year when it was 90 degrees. Hard to say for sure what's causing it.
Old Dec 16, 2010 | 09:47 PM
U are fine as long as ure not catted
Old Dec 16, 2010 | 09:49 PM
Reaper06's Avatar
18 max on my 2.7 vibrant header, catless n dynomax turbo muffler. rev limit will skew it some if you push it, it will always make more.
Old Dec 16, 2010 | 09:59 PM
On my old ss I made 18 on cold days. I had 2.6 60s and everything else but I had a lot of timing 22 no meth. that'll make a lil difference.
Old Dec 17, 2010 | 07:32 AM
Staged07SS's Avatar
Administrator
Administrator
this.
biniecki
Oct 25, 2015 02:23 PM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
DocSvensk
Sep 27, 2015 02:24 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
