Hitting redline/fuel cut question.
Old May 15, 2007 | 11:14 PM
rallyracer's Avatar
I notice that while shifting through gears really fast I sometimes bounce off the redline and I just want to know if this is bad for the engine?
I usually do this a few times a week.
Old May 15, 2007 | 11:25 PM
G85Cobalt's Avatar
i wouldn't recommend bouncing off it..if you know the redline is 6500 it will pull at 6300 i believe. so just get good at shifting just a hair b4 and u will be fine...
Old May 15, 2007 | 11:43 PM
Halfcent's Avatar
I'm old school
The computer is specifically protecting your engine by cutting fuel. It's not a problem to bounce off the limiter, but you shouldn't hold it there for any longer then you need to.
Old May 15, 2007 | 11:45 PM
Johnboy12358's Avatar
Bouncing off of the rev limiter too often can hurt things cant it? At any rate, its not something that I would suggest. I've done it like twice since I got the balt.
Old May 15, 2007 | 11:52 PM
spaz's Avatar
Thats what it is there for haha I hit it almost every day in first gear.Maybe I should reduce boost in first or somthing. haha.
Old May 16, 2007 | 10:26 AM
Halfcent's Avatar
I'm old school
Bouncing off the rev limiter is ok. Holding it on the limiter is not.
Old May 16, 2007 | 10:31 AM
D4u2s0t's Avatar
like said, it's not going to hurt anything, but i would suggest learning how to shift better...
Old May 16, 2007 | 10:35 AM
Witt's Avatar
As your car starts making more power with mods, try to stay away from the rev limiter. These cars use "fuel cut" rev limiters and can cause damage especially on a boosted engine. In stock form damage shouldn't be done unless it held against the limiter, but once the car starts making significant power over stock, you either should be staying away from it or convert to a spark based rev limiter.
Old May 16, 2007 | 10:45 AM
turboeco's Avatar
I thought they would have used spark cut vs. fuel, since it is a boosted engine.
Fuel cut is def. not good to be pegging off of.
Old May 16, 2007 | 10:47 AM
Witt's Avatar
I was surprised myself to see that the first time I looked at an LSJ file. I was pondering the thought of using the supercharger's desired torque setting to act as a spark cut rev limiter.
Old May 16, 2007 | 12:32 PM
LsJ2canada's Avatar
i seemed to have the same problem.. all i did was buy a shift light from raptor performance and since i have not done it.. i noticed when i didnt haveit.. it was hard to see the tach ??? is that just me or do other ppl have that problem
Old May 16, 2007 | 01:31 PM
Tomtwtwtw's Avatar
Like the other guys said, for the most part you're ok bouncing off the limiter once or twice, since it's there to protect you.
But in the words of Vincent Vega, "Just know, it's ******' dangerous to be drivin' a race car when it's in the red. It could blow."
Old May 16, 2007 | 06:27 PM
Maxim_X's Avatar
I'm almost positive they use spark cut, cause otherwise people wouldn't spit flames then they bounce it off it.
Old May 16, 2007 | 09:17 PM
Witt's Avatar
I wish it were, but sadly its not.
Stock '06 LSJ tune:
Old May 17, 2007 | 12:00 AM
Mikey851's Avatar
Wow, that is very suprising. I would've bet money on a spark rev limiter.
Edit: I wonder if maybe it's possible that when some of these guys get their car tuned that the person doing it does not know that the revlimit is fuel cut and does not adjust this along with everything else. What do you think?
Old May 17, 2007 | 12:09 AM
Rangerondubz's Avatar
Hmmm ima look into having this changed, is that why the SRT-4 limiters are real quick?
Old May 17, 2007 | 09:33 AM
Darksun's Avatar
you mean the machine gun rev limiters they have. who knows.
Old May 17, 2007 | 11:18 AM
Witt's Avatar
In that screenshot I provided above, change the Hyst (Gear) and Hyst (P/N) values to real low numbers and it should do the same thing.
hacadacalopolis
Oct 28, 2015 06:09 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 30, 2015 08:18 PM
Bohb
Sep 27, 2015 09:11 PM
