Hole in another cylinder
I was hoping to get some help and insight. I have put a hole in another cylinder again and also have to get it resleeved now. The mechanic is not sure how I did it and neither do I. Its an 06 ss/sc,gm stage 2,2.8 pulley,h/e, exhaust. Any help would be appreciated.
Lack of fuel, excessive heat, knock retard. You need a better tune, larger injectors, and gauges to ensure that your iat2's are in order. Your I/C pump could have failed also causing this. Either way, this will happen again and again if you don't change your setup and or learn.
Ya the 60's are going to have to happen. It seemed quite some time ago it was considered ok. I will have to hit you up about the hpt when I get it back if you don't mind.
courtesy of USMCfieldMP
Sep 28, 2015 12:51 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
