Holy Snow Performance...!?!?!?
Old May 4, 2007 | 05:53 AM
alaskacobalt's Avatar
Alright, today after I find out from someone, I plan on purchasing the Stage 2 Snow Performance Water/Meth kit. Do I need to purchase anything else along with the kit or can I just buy the kit and be perfectly fine?
Not sure if any of this matters but :
I am also planning on changing to a CA 2.79" pulley, and upgrading to -1 NGK spark plugs at the same time. For reference, I already have a SS/SC stage 2 w/Fujita.
Last edited by alaskacobalt; May 4, 2007 at 07:47 AM. Reason: my dog is officially so gay that his man poochy humping has interferred with my ability to process thought on the first try..
Old May 4, 2007 | 08:21 AM
Shortbus's Avatar
You will be fine with just the kit, and of course some fluid, but you cna also get a tb spacer from c/a that already comes with a taped line for the meth.
Old May 4, 2007 | 08:33 AM
Originally Posted by Shortbus
dooky dooky dooky.... but you cna also get a tb spacer from c/a that already comes with a taped line for the meth.
Alright... so what the hell does this mean? hahaha... line of meth? I'm military folks... I can't be doing lines... a **** test is always just around the corner!
Last edited by alaskacobalt; May 4, 2007 at 08:34 AM. Reason: I overstretched my sack while changing out my pulley, which caused a lapse in my ability to post correctly.
Old May 4, 2007 | 12:36 PM
XCRuna1201's Avatar
It is a spacer that you put between the supercharger and the intake that has port so you can hook up the meth straight into your intake. No Drugs here ha ha
Old May 4, 2007 | 12:42 PM
I just did some research on it, and it's strange that I hadn't found it before. I know I've seen it, but I never looked close enough at it, to realize that it had that capability. But it's my understanding with this, that I still need to have the complete water/meth kit. Would the benefit of having the spacer be great enough to warrant the cost?
Also, would it be realistic to run a CRY02 system along with the meth/water or should I just go with a single setup? It appears to me that there are different benefits to each, so to combine those benefits could be quite useful. I'm tbinking about the CRY02 with the intake bulb in combination with the meth/water kit or is this just overkill?
bigdeertz
Nov 17, 2016 09:41 AM
TedSS
101
Apr 25, 2016 10:46 PM
Jan 12, 2016 12:01 AM
Northindy
Oct 31, 2015 01:35 PM
Sep 27, 2015 08:53 PM
