hopping issie still
didn't know ottp made a CA bushing. i only knew the poly ones besides stock
they look weird. Do they go on that pin in the front?
are you looking at the delrin bushing? its not those. these are the ones that have failed me multiple times
http://www.ottperformance.com/store/...ings-41p86.htm
gonna do it soon. that last time my control arm bushings failed they were not available yet
Last edited by BLAZIN07SS; Jun 10, 2010 at 08:46 AM. Reason: Automerged Doublepost
yeah the circle ones. Do they go on the pin still like the others? I saw the derlin ones. what happened with those ones?
ok someone enlighten me scabs?
ohhh ok, and the delrin ones replace the ones in the pin. that scab bushing is gonna be a lil bnasty to get out i can see it already.
an then some.... you gonna say something else? So when you replaced these basically the hop went away?
when you install those stage 1 or 2 mounts, YOU HAVE to loosen the 3 bolts that connect the side passenger engine mount. Then the engine/trans will move some. then retighten. I think they tighten to 45ft/lbs.
If he didn't reduce 1st gear power(reducing tire spin) thus "eliminating" wheel hop because you have less power now, what did he do Einstein? eh?
Go pahk yah cah at Habbad Yahd till you get me an answer.
Hey man .... I posted your advice you gave me a month or so ago about the 3 bolts on page 2. Everyone in this thread over looked it. It helped me, and it will def. help the OP.
ya, i could barely install my front mount, had to use a pry bar, then John told me about those 3 bolts :duh:! It should help a ton!
Do the CABs help noticeably with other driving performance? I've been considering them but not sure what to expect on normal driving / road coursing.
You'll notice ottp cabs right away in the handling dept. They make your car feel super tight..it's been one of the best suspension upgrades I have done.
