how to adjust shift cables
Old Nov 19, 2007 | 05:41 PM
JDMjunkie's Avatar
can anyone tell me how to adjust the shift cable? i installed a B&M short shifter a couples weeks ago and its been kind of hard to get it in reverse. Also when i go to put it in 5th i have to lift up on the reverse lock-out..any ideas?
Old Nov 19, 2007 | 05:43 PM
Blackout06LS's Avatar
Did you mark the cables with a sharpie like the instructions say?
Old Nov 19, 2007 | 05:48 PM
JDMjunkie's Avatar
yes.
Old Nov 19, 2007 | 05:49 PM
elecblue06's Avatar
that didn't help me the bend in the shifter is alot different for me so i have to fix it.. i'm just lazy/ used to it now
Old Nov 19, 2007 | 05:52 PM
I ground a little going into 2nd. Find the cable that is the R cable put a small ruler down there, and mess with the settings some. When your in R. You want the cable going the farthest.
Just be careful. And be patient. Can't rush it.
Old Nov 19, 2007 | 06:34 PM
chood711's Avatar
there are 2 cables, the one on the left is the one you need to mess with, pop the clip with it in neutral and move the shifter to the left a little and then pop the clip back in. that should take care of it.
Old Nov 19, 2007 | 06:38 PM
elecblue06's Avatar
my shifter sits a bit to the left and forward.. i gotta fix it so it's straight up in neutral i'll probably tackle that when i install my intake though since it was a bitch to do the first time
Old Nov 19, 2007 | 07:53 PM
chood711's Avatar
the good thing about is all you have to do is remover the shifter boot and can mess with them that way
Old Nov 19, 2007 | 08:37 PM
yellowspeed5's Avatar
take it to a speed shop
RaginChopsuey
Oct 27, 2015 01:27 PM
justinchinn
Oct 2, 2015 12:18 PM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
