How to check if your Intercooler Pump is working ok
Old Nov 25, 2010 | 11:21 PM
xxxxsh4d0wxxxx's Avatar
Originally Posted by ebristol
Where is the drain on the LSJ's intercooler system?
For the radiator.. It's on the passenger side.. I'm sorry, I read it incorrectly. The LSJ DOES NOT have a drain for the H/E system.. Only a bleeder valve which is accessed by removing the driver-side headlight.
The best way to tell if the IC pump is working is to turn the key to the Run position without starting the car. After 10 seconds, the IC pump should kick in and you will hear a buzz coming from the engine bay.
When these pumps fail, the buzzing stops.
This. Turn the car on, take off the cap, you'll see coolant bubbling/sloshing around. If it's just chillin there, it's dead.
Originally Posted by chrisjaldin
Then why the milky white color of the coolant?
I'm not sure.. That is strange, but a blown head gasket would not turn the H/E system's coolant milky. Two different systems. There is no possibility that it could see oil, that I am aware of.
Originally Posted by trey ss
ive had to check on mine often bc it quits working so i smack that bitch with a hammer
FTW
Old Nov 25, 2010 | 11:48 PM
Axelthered05's Avatar
^Epic ^
Old Nov 26, 2010 | 05:40 AM
tanelk's Avatar
wHat if the coolant overflows after removing the cap with the car on, does that mean it still works?
Old Nov 26, 2010 | 06:24 AM
That means the system has pressure and you just relieved it.
Old Nov 26, 2010 | 03:51 PM
tanelk's Avatar
What happens if you drivve the car and your ic doesn't work
Old Nov 26, 2010 | 04:06 PM
tanelk's Avatar
Anybody
Old Nov 26, 2010 | 04:11 PM
boost_junkie16's Avatar
IAT2's go through the roof. Basically asking for your engine to go
Old Nov 26, 2010 | 04:47 PM
tanelk's Avatar
Ok so I'm pretty sure mines is out, the coolant just sits there. Any other things to check before buying a new ic.
Old Nov 26, 2010 | 05:31 PM
chrisjaldin's Avatar
What temperature is normal for the intake?
Old Nov 26, 2010 | 05:50 PM
I here the buzz sound coming from the engine bay, IC pump is ok. but color scars me out...
Any final diagnose before opening my engine and replacing a head gasket???.. and if it was a blown head gasket...it shouldn't be brownish like oil color??
Old Nov 26, 2010 | 05:53 PM
  #36
chevysssc's Avatar
cruising iat2 should be 20*ish above ambiant temp. in your pics the engine coolant color looks good in the res. the oil seams fine. now the s/c coolant looks funky. it looks like you mixed the wrong coolant with dex-cool. if u mix the wrong stuff it will foam up.
Old Nov 26, 2010 | 05:54 PM
  #37
chevysssc's Avatar
s/c coolant needs to be changed. everything looks fine pics helped.
Old Nov 26, 2010 | 05:59 PM
  #38
Could you help me out with the process?
Old Nov 26, 2010 | 06:08 PM
  #39
damien's Avatar
How to by area 47. Flush and fill the IC system.
Also going to add, if the car has a stock or GM tune the pump will NOT kick on unless the engine is running.
Old Nov 26, 2010 | 06:22 PM
  #40
tanelk's Avatar
I had engine running, coolant just sat their
Old Nov 26, 2010 | 06:26 PM
  #41
chevysssc's Avatar
since you said you cant get dex-cool, id say take a hose end off the heat exchanger (middle radiator ,under car) empty as much into a container. then put a garden hose into the filler neck (infront of the s/c) and flush as much out as possible. then re-fill with 1 kind of 50/50 coolant.
Old Nov 26, 2010 | 06:27 PM
  #42
chevysssc's Avatar
ottp black friday sale has ic pumps for $94
Old Nov 26, 2010 | 06:45 PM
  #43
tanelk's Avatar
Lol, you know if it wasn't for your thread I would have never really check out the ic
Old Nov 26, 2010 | 07:10 PM
  #44
tanelk's Avatar
The ic pump is located where
Old Nov 26, 2010 | 09:03 PM
  #45
tanelk's Avatar
Anyone
Old Nov 27, 2010 | 01:12 AM
  #46
Its on the passenger side below the intake manifold (a little bit to the side). It has a steel bracket. Or just following intercooler hosing system. You should find it
Old Nov 27, 2010 | 02:22 AM
  #47
CleverOne's Avatar
In all seriousness, locate the pump and wack it with a rubber mallet a few times, then check it again. I had to do this to mine and it fixed it. I am guessing the brushes get buildup on them and hitting it with a hammer breaks the stuff loose.
Old Nov 27, 2010 | 07:50 AM
  #48
paddock's Avatar
As far as the pump goes... you can check it with the car off. Just pull the relay and use a jumper wire and jump the pins (82 and 30.. or sumtin like that), you'll hear the pump running then...
Old Nov 27, 2010 | 10:36 AM
  #49
chevysssc's Avatar
hammer never fixed mine but it can somtimes
Old Nov 27, 2010 | 11:27 AM
  #50
tanelk's Avatar
I fix it, smack the **** out of it with the hammer and the coolant started bubbling.
