How to check if your Intercooler Pump is working ok
For the radiator.. It's on the passenger side.. I'm sorry, I read it incorrectly. The LSJ DOES NOT have a drain for the H/E system.. Only a bleeder valve which is accessed by removing the driver-side headlight.
This. Turn the car on, take off the cap, you'll see coolant bubbling/sloshing around. If it's just chillin there, it's dead.
I'm not sure.. That is strange, but a blown head gasket would not turn the H/E system's coolant milky. Two different systems. There is no possibility that it could see oil, that I am aware of.
FTW
I here the buzz sound coming from the engine bay, IC pump is ok. but color scars me out...
Any final diagnose before opening my engine and replacing a head gasket???.. and if it was a blown head gasket...it shouldn't be brownish like oil color??
cruising iat2 should be 20*ish above ambiant temp. in your pics the engine coolant color looks good in the res. the oil seams fine. now the s/c coolant looks funky. it looks like you mixed the wrong coolant with dex-cool. if u mix the wrong stuff it will foam up.
since you said you cant get dex-cool, id say take a hose end off the heat exchanger (middle radiator ,under car) empty as much into a container. then put a garden hose into the filler neck (infront of the s/c) and flush as much out as possible. then re-fill with 1 kind of 50/50 coolant.
In all seriousness, locate the pump and wack it with a rubber mallet a few times, then check it again. I had to do this to mine and it fixed it. I am guessing the brushes get buildup on them and hitting it with a hammer breaks the stuff loose.
As far as the pump goes... you can check it with the car off. Just pull the relay and use a jumper wire and jump the pins (82 and 30.. or sumtin like that), you'll hear the pump running then...
