how do i get boost gauge out
any body know how to get the boost gauge out. gauge stopped working. do you have to take the piller off or does the gauge pop out. I have the airbag behind the piller.
Thanks.
Thanks.
Just take that pillar off. That little piece that says airbag is not actually the airbag. Its just a cap. Take that off and there is a screw there that you will need to take out. Once that is out, the pillar can be pulled out (dont pull to hard, seeing as the boost gauge will still be connected). After that, you will see that the boost gauge is held in by two tiny bolts. Undo those bolts and disconnect the wires, and the boost gauge should fall out.
The stock boost gauge is only held in by the pillar and the connector....
Pop off the cap that says "AIR BAG" behind it is a screw, unscrew it, pull down the pillar disconnect the connector on the gauge, and pull the gauge out from the front!
