how do you all shift??
Old Sep 12, 2006 | 06:31 PM
2fastSS's Avatar
ok basically im makin this thread to find out how hard you all power shift...
do all of you power shift from 3rd to 4th or 2nd to 3rd or 1st to 2nd idk whichever but still do you shift to where you slam it down and you can hear it??
do you also shift so hard that when your power shifting that your tires squeek at high gears and your car acts like it doesnt like you haha
LET ME KNOW
thanks
Old Sep 12, 2006 | 06:34 PM
tube's Avatar
I used to power shift the hell out of it from 1-2 and 2-3, but usually only when racing.
Old Sep 12, 2006 | 06:39 PM
AlphaJaguar5's Avatar
I try to start out in 1st then go into 2nd before I hit the limiter then usually if I want to keep going I'll put it in 3rd once 2nd gear is over. If I'm still going fast and want to go even faster I'll slam it in 4th right as 3rd is ending. Its funny though if your going in 4th and your going REALLY fast I found out that you can put it in 5th and it'll keep going, go figure. lmao, sorry
Old Sep 12, 2006 | 06:42 PM
2fastSS's Avatar
what i was reffering to this was like say your shifting but do you shift to where its hard and your axles are feeling it to but do u shift hard enough to where your going with your limiter and all??
Blown 4-banger's Avatar
To keep from having the famous "you think it went in gear, but when you let the clutch out it grinds" I slam it into gear so hard sometimes I'm scared i'll break the shifter off! It works for almost never missing a shift and getting really fast shifts.
Old Sep 12, 2006 | 06:49 PM
boostedss26's Avatar
I slam the gears hard and fast to where the rpm's don't get a chance to drop and at the track i don't even let off the gas when i shift "power shift"
Old Sep 12, 2006 | 07:16 PM
ggarcia86's Avatar
me personally, i shift like a fat idiot.
or... rather i use lift throttle shifts just before the rev limiter(if driving with enthusiasm), never power shifting(without letting off throttle) for fear of my clutch slipping...
Old Sep 13, 2006 | 02:05 AM
FLCobalt's Avatar
i power shift every gear, thats the only way i can assure no slippage. Usually start the shift around 6000 rpms.
RaginChopsuey
Oct 27, 2015 01:27 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
The Rookie24
Sep 20, 2015 04:33 PM
roadrunner132
Sep 19, 2015 04:35 PM
