how does this sound guys?
Old Aug 2, 2007 | 05:04 PM
arng22's Avatar
well an extra 800 bucks a month helps so i figure i will start building up my balt a bit..how does this setup sound to you pros..
CA stage 4.
2.6pulley-i want to go 2.8 to be safer
ZZP Interchangeable Pulley system
2 step colder ngk IRIDIUM spark plugs
GM shortened belt
ZZP Adjustable Tensioner
60# Siemens Injectors
Injector Wiring Harness
and that comes with some sort of retune?..i'll most likely get a custom hpt.
on to the rest..
i'll keep my injen
sticking to my GM for the exhaust..so...
-GMPP manifold
-corsca touring
-hurst short throw
traction time!
-ZZP BILLET Engine Mount
-ZZP LSJ POLY Trans Mounts
ive done a bit of research and come up with that before id be forced to start with meth and Heat ex.
does that sound good to you guys?
would it be safe?
..figure it would set me around 275-280whp 19-20psi
and i figure the second half of September is when ill start rolling in the parts to start the build over the winter
any advice will be welcomed thanks!
EDIT: going with the 2.8!
Old Aug 2, 2007 | 05:07 PM
Area47's Avatar
Rent me! per hour
i would go with something better on the headers ide of things then a ported manifold.
you can get 270 to the tire with a 2.8
CobaltVenomSS's Avatar
that 2.6 pulley has been blowing up engines i think the lowest ill go is 2.8
Old Aug 2, 2007 | 05:10 PM
arng22's Avatar
[U]
good to know..i am not going for over kill..maybe a mid 13 safely.
i know i know...2.7 seems safe with 60lbers tho.
Old Aug 2, 2007 | 05:11 PM
Coblt ss super's Avatar
2.8 FTW!! safest size ever, thats why im doing it
Old Aug 2, 2007 | 05:16 PM
arng22's Avatar
3-1 on the 2.8 pulley...i think i'll switch to the 2.8
again i am going for safe fun rather then blowing my motor. thanks everyone +rep
Old Aug 2, 2007 | 05:20 PM
Shortbus's Avatar
Save yourself some money and just build your own kit and just get a 2.8, 60s, stage 2 belt, and hp tuners tune.
Old Aug 2, 2007 | 05:22 PM
M-Dub's Avatar
2.8 FTMFW! Once I get my meth kit installed I'll be buying a 2.8 I am running a 2.85 right now!
Old Aug 2, 2007 | 05:23 PM
arng22's Avatar
the stage 4 is 750...if i pieced the kit together it would be cheaper?
Old Aug 2, 2007 | 05:26 PM
Area47's Avatar
Rent me! per hour
i have a 2.8
not going any lower than this. i like my blower. besides, i rarely race. so i have no need to prove something to people.
i have never ran at the track with a 2.8
however, i have run a 13.7@103 on the stage 2 pulley
Old Aug 2, 2007 | 05:28 PM
Shortbus's Avatar
i have a 2.8
Exactly, and on the other hand people with smaller pulleys have ran about that time or slower! I think 13s for a econo street daily driver is good enough for me!
Old Aug 2, 2007 | 05:32 PM
chevysalesman614's Avatar
in 3 months(of saving) you could have the blower swap or turbo swap. why would you waste money on an inefficient setup? (2.6)
your warranty will be toast anyway, so why not get the twinscrew? plus its only gonna be like $2,000 more than the power mods you've chosen.
so you wait 3 months, get the better blower, and add some traction mods a little ways down the road. (to give you a break)
arng22's Avatar
shortbus you just saved me like 400$ i got a few questions...with going with the 2.8 can i just get a 2.8 to fit the gm snout? from zzp? without the pulley changer system..
and..*embarrassed* were can i get hpt? my friend works with that bs can he figure it out..or can i go to a local place that tunes?
Old Aug 2, 2007 | 05:39 PM
arng22's Avatar
want to keep my m62.
really have no desire for a turbo and all the work that goes with it
in what way is it inefficient?
Old Aug 2, 2007 | 05:40 PM
yeah. post in your regional forum.. or search through it, to find out where the local guys are getting tuned.
Old Aug 2, 2007 | 05:41 PM
Area47's Avatar
Rent me! per hour
what state are you in?
no, the 2.8 will not fit the stock hub, you need the pulley system, or stage 2 hub to get it to work. the stock pulley is a press on. the rest of bolt ons viw using the stage 2 hub, or the interchange system
Old Aug 2, 2007 | 05:43 PM
i thought you were running a 2.6 at first. they make some heat.
there is no stock hub. the stock pulley is a press on pulley.
Last edited by chevysalesman614; Aug 2, 2007 at 05:43 PM. Reason: Automerged Doublepost
Old Aug 2, 2007 | 05:46 PM
arng22's Avatar
i have GM stage2..got it with the car
nah..i want to stick to the 2.8 again..ill be happy with a mid-high 13 safely rather then blowing up my lsj running meth and a 2.6 or lower ect ect.
guess the question would be is there a 2.8 pulley for the gm stage 2 hub?
and i am in New Jersey
Old Aug 2, 2007 | 05:49 PM
Shortbus's Avatar
Yes you get get nate to make you a 2.8 to fit the hub, there is also pulleyboyz, and CA makes a 2.79 to fit the gm hub.
Old Aug 2, 2007 | 05:53 PM
arng22's Avatar
would this work?
http://www.zzperformance.com/cobalt_...=613&catid=142
Old Aug 2, 2007 | 05:57 PM
SteelCharger's Avatar
-GMPP manifold
-corsca touring
Ok, you said your sticking to GM but then list a Corsa exhaust? Does GM sell the Corsa through the dealer along with the GMPP systems.
BTW you will like the Corsa Touring, I've had mine on for about a week and I love it. Great sound not raspy and annoying at all.
Old Aug 2, 2007 | 06:00 PM
arng22's Avatar
http://www.crateenginedepot.com/stor...P1626C146.aspx
not sure how it works..im sure corsa is under gm tho..
Old Aug 2, 2007 | 06:01 PM
tlax23's Avatar
the ZZP pulley will work however... there is a guy on here named nate that sells polished pulleys to fit the gm stage 2 hub that are less expensive
make sure you run some cooling mods just for extra protection if you have the cash such as dual pass/heat exchanger/water injection
Old Aug 2, 2007 | 06:02 PM
R&C_rallySS's Avatar
I agree with some peeps, get a better header. I would get the ZZP header downpipe combo.
arng22's Avatar
i was gunna go HE at the end of the setup
