How hard does Intense Pulley puch on?
Old Mar 9, 2006 | 06:56 AM
BlackSS/SC's Avatar
I'm installing the intense pulley hub and it's on almost the whole way but now it's getting extremely hard to turn the 15/16" nut. It's only gotta go about one belt groove width. Then the end of the hub will be perfectly even with the end of the shaft. Does it normaly get really hard to make it go that last little bit? I'm using the Intense Pulley tool by the way.
Old Mar 9, 2006 | 08:57 AM
StreetDreamz's Avatar
Yes, use a little muscle. It will take about the same force to put it on that you took to take it off. If you recall how hard that was you will know. It has a slight taper to it so the farther back it goes, the harder things will become. I have the Intense hub, fits on the end of the shaft perfect and lines right up. If you are using their tool it will stop exactly at the end of the shaft if you have it on their right. This way nothing gets distoreted or messed up.
Old Mar 9, 2006 | 09:45 AM
BlackSS/SC's Avatar
Thanks, I will try to put some muscle into it. I just didn't wanna screw anything up!
Old Mar 9, 2006 | 01:32 PM
italstalnprd86's Avatar
when i put my pully on it went on hard because it was backwards..... so after taking it off and putting it back on again, and breaking the tool about 5 times..... it is on.....
Old Mar 9, 2006 | 01:33 PM
also heating the pully with a blow torch makes it go one a lot easier too.....
Old Mar 9, 2006 | 01:42 PM
BlackSS/SC's Avatar
Which part faces out? The flat side?
Old Mar 9, 2006 | 02:07 PM
on my zzp it is the flatter side, not the side with like the thing sticking out of it, the stock one is made different and is opposite....
Old Mar 9, 2006 | 02:16 PM
Rogue's Avatar
Flat side out. The pulley will mate to its flat surface.
Old Mar 9, 2006 | 02:17 PM
theBLUEone's Avatar
Yea, the side where you bolt the hub on is what sticks out...
Old Mar 9, 2006 | 03:08 PM
BlackSS/SC's Avatar
Thanks guys. I'll try tonight when I get home. I've got the hub on the right way but it just didn't seem like it would go on anymore as we cranked the hell out of it and it didn't seem like it would go.
Old Mar 9, 2006 | 03:23 PM
Rogue's Avatar
The hub should fit flush on the end of the snout.
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
