How to install the 2.8 pulley on a staged balt
The way I did it, was use a pry bar. Put the one end of the pry bar under the supercharger pulley, and pry the tesnioner down. Then I took the 15mm wrench and placed it over the little hump on the right hand side of the tensioner (if you're looking at the engine straight on), removed the pry bar, and then removed the belt while holding the tensioner down with the wrench.
Sorry, I never took a pic. I would go and take one right now, but it's dark out and raining. I'll try and take one tomorrow for you. I can tell you, this way is a lot easier than just using the 15mm wrench by itself.
patooyee
Oct 1, 2015 01:07 PM
