how to keep your lsj alive in the winter
Old Nov 25, 2008 | 01:07 PM
Area47's Avatar
Rent me! per hour
it's that time again kiddies. it gets colder, people blow the **** out of their lsj's.
here is a friendly helper to keep your car living during the winter time.
if you have a smaller than stage 2 pulley on your car and are not the tuner of your car. go up in sizes. your afr will swing good to richer than normal. most people don't take the time to tweak their maf cals with an error window in it. so go up in sizes.
straight stage 2 car?
leave it.
stock?
leave it.
tvs cars?
work that maf call until you get actual/cmnd. even with meth you will have to command richer than normal.
change your plugs. lower the gap a smidge. don't beat on the car a lot.
Old Nov 25, 2008 | 01:08 PM
WSFrazier's Avatar
Bah, paranoid people. Blowing it up is 90% of the fun, anyway.
Old Nov 25, 2008 | 01:10 PM
REIGN SS's Avatar
Original Hayden Fanatic
Are you dying?
Old Nov 25, 2008 | 01:11 PM
Area47's Avatar
Rent me! per hour
go play with your single cam honda
06blackg85ss's Avatar
lol.
as for my car, **** it,. I keep it set the same.... from rocky 4... if it dies, it dies lol.
Old Nov 25, 2008 | 01:12 PM
Area47's Avatar
Rent me! per hour
Originally Posted by REIGN SS
Are you dying?
uh no
ran a comp test. cold the other day
206
205
207
205
car is fine
Old Nov 25, 2008 | 01:13 PM
SSdan's Avatar
Area what's the difference in doing cold vs hot test?
Area47's Avatar
Rent me! per hour
Originally Posted by 06blackg85ss
lol.
you don't care. it's the kids who beat the **** out of their cars and then make a thread on here about "i blew my car up"
you on the other hand will laugh like a school girl when you do it.
then al and wes will get a call.
Old Nov 25, 2008 | 01:14 PM
ShortStack's Avatar
Thanks Area..!
now hopefully people just listen, so we dont have to answer in threads that start with "engine blew help!!"
Old Nov 25, 2008 | 01:15 PM
Area47's Avatar
Rent me! per hour
the lsj has a ****-tastic baro sensor that doesn't like to compensate for colder temps. so it runs leaner. leaner = power, but also equals more heat.
Witt's Avatar
leave it.
stock?
leave it.
tvs cars?
should be built anyway so leave it.
Fixed!
Old Nov 25, 2008 | 01:16 PM
Area47's Avatar
Rent me! per hour
Originally Posted by Witt
Fixed!
we're not going there again slow one
SSdan's Avatar
Oh no not that. I knew that.
I was referring to comp testing when the motor is cold vs hot.
I usually do mine when it's cold or the coolant temp is around 110 degrees, give or take.
WSFrazier's Avatar
Fixed!
+1, Drop a set of Diamonds in for ~600 and call it a night.
Old Nov 25, 2008 | 01:18 PM
Witt's Avatar
Baro compensates for MAP measurements at different altitudes. IAT1 compensates for MAF changes at different temps.
Its the calibration, not the sensor.
Fine then nervous one.
Old Nov 25, 2008 | 01:19 PM
Area47's Avatar
Rent me! per hour
newp. even with my calibration dead on it still has a mind of it's own.
i however, don't really care
Old Nov 25, 2008 | 01:20 PM
Witt's Avatar
Not the MAF calibration, the IAT correction that you can't adjust.
Old Nov 25, 2008 | 01:21 PM
Area47's Avatar
Rent me! per hour
::looks at time slip::
im nervous? i have a right to be, im faster than you!
******* hpt
you got that right lol.
I know when it does decide to go, it's not gonna be some ***** cracked piston.... **** will be hitting everything around me lol.
Old Nov 25, 2008 | 01:22 PM
Witt's Avatar
******* hpt
Maybe on stock blower cars, not on TVS ones.
Thats a man's way of doing it imo.
Old Nov 25, 2008 | 01:23 PM
******* hpt
I"ll second that
InfinityzeN's Avatar
It's a good thing I'm tuned for ~50* weather. That is actually a little colder then it gets her most of the time. I also spent a long time on my VE and MAF.
Cheers though, seems most of the people who blow their LSJs up do it during the winter.
WSFrazier's Avatar
Just like Dan, couldn't of just spun a bearing and just stop driving it. Had to put a hole in the block...
Old Nov 25, 2008 | 01:24 PM
hell yeah, no ***** footing around there..... I like to see through my motors, gives me a sense of accomplishment. lol
Area47's Avatar
Rent me! per hour
if you beat my time, you hit 12's. it's that simple mr i need 25psi to do it.
