how many of you have meth injection?
Old May 16, 2008 | 05:03 PM
yeah high 9s in a/f ratio would be rich as hell, which is ALWAYS better than running lean. If he was that far in the other direction from his 11.5 tune then that would be bad. Im getting snow's meth setup probably in another month along with my cxracing h/e and dual pass with option b setup. Once I get that squared away im going to drop down to a 2.7 from a 2.9. With the cooling mods im going to get tuned, then drop the pulley and adjust the tune as needed from there. Should be good to go then!
Old May 16, 2008 | 05:35 PM
ralliartist's Avatar
I'm tuned 12:1 all the way up. It's perfectly safe on meth.
Old May 16, 2008 | 05:39 PM
SJSchafer's Avatar
Yea, I guess. On the other hand, cylinder wash is no joke either. I guess my point was just that I never recommend anybody do anything that will change their AFR without getting a tune. Even a CAI in my opinion should be tuned for. Header/DP, meth... They should all be tuned for, because you never know when that one stupid mod that everyone thought was okay to do without a tune can throw your AFRs in the danger zone and "POP!" there goes a piston, or a ring, or... Besides that, if you think about it, what mod can you do to your car that doesn't "require" a tune will get you as much HP per dollar as a tune?
Try lowering your AFR in PE to 11.8 at about 3k rpms and work up to your 12.1 at 5k and up. You might like it.
Old May 16, 2008 | 05:49 PM
Area47's Avatar
Rent me! per hour
sssssshhhhhhhhhhhhhhh
don't give it all away
i love it when people don't have a clue what they are talking about, jump into a conversation without any background or personal use of it.
pimp. wrong answer bud.
Old May 16, 2008 | 06:06 PM
SJSchafer's Avatar
lol. d00d. Stop stalking me.
Besides, I've not had a chance to try that yet with meth. Just going with my limited knowledge of physics. I was hoping he would try it and tell me if it works.
Oh, and I hope you won't be running that 2.7 on stage 2 injectors. Even with meth, you'll **** them off in a very unpretty way.
Old May 16, 2008 | 06:34 PM
Area47's Avatar
Rent me! per hour
you're stalking me!
sometimes. it's better to sit back and let people do what they want.
Old May 16, 2008 | 06:45 PM
SJSchafer's Avatar
you're stalking me!
I posted here first!
But if I let everyone do whatever they wanted, people would be blowing up cars and I would have nobody to send me PMs all the time and...
Hmmm... Never mind, run meth without tuning. Oh and max out your IFR table at 63.5 and... and... and... zero out your adders... and... and... and... bounce your car off your rev limiter... and... and... and...
***sigh***
Old May 16, 2008 | 06:51 PM
Area47's Avatar
Rent me! per hour
::shrugs::
i stopped caring
life is easier this way!
Old May 16, 2008 | 07:35 PM
SJSchafer's Avatar
::shrugs::
i stopped caring
I am not yet that bright.
Old May 16, 2008 | 07:50 PM
InfinityzeN's Avatar
Anyone tried starting with an AFR ~11 and slowly leaning out to ~11.5 by around 5k rpms? That would be without meth of course, but I'm just wondering.
Old May 16, 2008 | 07:57 PM
  #36
ColeJJones's Avatar
Bannned
dont know numbers. i run the ais kit
meth does cool yes. but adds horsepower when you tune for it. you pull timing... more hp
Last edited by ColeJJones; May 16, 2008 at 07:57 PM. Reason: Automerged Doublepost
Old May 16, 2008 | 08:18 PM
  #37
SJSchafer's Avatar
Physics 101:
Rich adds torque, lean adds HP. Where is our torque curve the strongest? Where is our peak HP? I've done 11.2 low - 11.7 high with decent success, but without access to a dyno, it's just speculation. The one chance I got to dyno, I pulled a lot harder commanding 11.4 low than commanding 12.4 low and working down to 11.5 (like most want to do it). The bad thing is the dyno kept flipping out at around 5000-5500rpm (iirc), so I got no reading above that. Car definately likes rich down low though.
Old May 16, 2008 | 08:23 PM
  #38
Yea, right now my tOoN is set to 11.2~11.3. I think I'll get that to lean out to 11.5 higher up in the rpm range.
Old May 16, 2008 | 09:46 PM
  #39
Screw stage 2 injectors, got rid of those things many mods ago. Running 60s fo sho. Dont worry man, i got it covered
Old May 16, 2008 | 09:50 PM
  #40
hatrickstu's Avatar
Originally Posted by Darkmanx
It doesnt add anything because you already have it . IF i have 30 dollars and someone gives me a wallet so i dont loose the money by putting it in my pocket i didnt just gain more money by getting a wallet. its just preventing me from loosing my money.
best explanation ever. haha
Old May 16, 2008 | 09:59 PM
  #41
SJSchafer's Avatar
LOL. Not really.
Old May 16, 2008 | 10:00 PM
  #42
lsjwannabe's Avatar
x2..
Old May 16, 2008 | 10:48 PM
  #43
hatrickstu's Avatar
LOL. Not really.
it was just funny how his analogy was spot on with his side of it. i was more impressed with the analogy than anything
Old May 27, 2008 | 04:17 PM
  #44
Kibosh3's Avatar
i just got my tune for 50/50 mix..i must say that i am impressed with the results ...lots of pull in 2nd gear now
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
