how to modify the lsj thermo and oil cooler adapter for external cooling
Old Nov 5, 2012 | 11:24 AM
mrbelvedere's Avatar
take your thermo housing and cut the nipples going to the oil cooler off and tap the holes for 3/8 pipe and plug them
unbolt the silver cooler from the oil cooler adapter weld 2 -10 bungs to it get your appropriate fittings and line in -10 size and a oil cooler of your choice with -10 inlet and outlet build your lines mount it up enjoy cooler oil and engine temps and increased capacity
Old Nov 5, 2012 | 11:25 AM
Omnigear's Avatar
pictarz r small =(
Old Nov 5, 2012 | 11:34 AM
photo bucket sucks and i dont know how to fix
Old Nov 5, 2012 | 03:38 PM
YelCal7's Avatar
What does it do ? I am curious, I may do this.
Old Nov 5, 2012 | 04:37 PM
it gets rid off the stock oil cooler and puts it out front
Old Nov 5, 2012 | 04:48 PM
Pleass's Avatar
Post pic of your oil cooler also
These pics kinda sucks
Old Nov 5, 2012 | 07:40 PM
you dont think i dont know the pics suck
Old Nov 5, 2012 | 07:41 PM
TStone's Avatar
You don't know anything ya ol man
Old Nov 6, 2012 | 09:45 AM
Pleass's Avatar
this would be a waste of time
Old Nov 6, 2012 | 10:10 AM
realy it would be a waste of time dude your completly clueless have you done this apparantly not so therefore you havent seen the results so stay out of my threads your a bum
Old Nov 6, 2012 | 01:36 PM
Speedytec's Avatar
Why this mod? You ran out of oil cooler capacity??
Old Nov 6, 2012 | 01:49 PM
OneCOLDBIZL272's Avatar
This is what John did. Same thing I did a while back.
https://www.cobaltss.net/forums/2-0l...set-up-219490/
Old Nov 6, 2012 | 01:52 PM
Omnigear's Avatar
your a waste of time
linky no workie
Old Nov 6, 2012 | 01:59 PM
Link works for me I just edited again. If not search threads if created you'll find it.
Old Nov 6, 2012 | 02:05 PM
Omnigear's Avatar
works
Old Nov 6, 2012 | 02:06 PM
Kk kool
Old Nov 6, 2012 | 02:09 PM
Omnigear's Avatar
i remember that thread =p
Old Nov 6, 2012 | 02:10 PM
Omnigear's Avatar
Kk kool
make a how to ^_^
Old Nov 6, 2012 | 02:15 PM
I would imagine I believe you posted in it lol. Only differance is John also welded his. I felt confident with just tapping mine. Hasn't leaked at all. Also leaves the option with just tApped to put it back to stock if I wanted to. But there's nothing wrong with welding it like John did.
Old Nov 6, 2012 | 02:18 PM
make a how to ^_^
If I get the time. In the next few weeks I try too
Other wise John for sure could too
Last edited by OneCOLDBIZL272; Nov 6, 2012 at 02:18 PM. Reason: Automerged Doublepost
Old Nov 6, 2012 | 02:22 PM
Out of all the custom **** I've done you sir are the first to ask for a how too.
Old Nov 6, 2012 | 02:30 PM
the stock oil cooler is junk period ive seen them crack and mix coolant and it can over tax the coolant system(another reason the lnf got mpre coolant capacity) it also increases the oil capacity and gives you a place to pre oil a fresh engine before startup
i dont run that plate i have a custom one that gets rid of the thermostat
Old Nov 6, 2012 | 02:36 PM
Staged07SS's Avatar
Administrator
Administrator
Good info in here.
Old Nov 6, 2012 | 02:44 PM
Yeah I know your setup is a lil different. Yeah I was refurring to the oil cooler part. I've seen block of Tstat housing to delet the t-stat. There's a company that makes them for Ecos. I'm lost other wise John lol.
Old Nov 6, 2012 | 07:35 PM
the oil cooler thermostat that is
